I have a Nikon D40. I had a problem with the flash which suddenly didn't work. Using an online repair, I fixed the flash successfully. But now the flash will not pop up. I will soon disable the flash again and just use my external flash unless someone can help me with the pop up factor. The catch does not release.
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
For future reference to others with this same problem of the flash not popping up... I also followed the video (http://www.vimeo.com/3141400) to remove the cover from the flash & noticed on the L (or V) piece that he shows, hooks around the screw- look just BELOW that & you will see 2 small "U" shaped brackets. My two u shaped brackets just below the L were not level with each other, one metal bracket was pinned down under the L shaped bracket. As soon as I pulled it out & made the two brackets level with each other, viola!! The flash pops up & fires- no more smoke smell & saved myself $94-200 that Nikon quoted me to have it looked at & fixed. Hope this helps, wish I could post pictures on here of what I'm talking about :) (comment to me here & I'll e-mail them to you)
do you still have the pics? I am having a terrible time
Thanks. The battery is charged. It stopped popping up after I repaired the flash that wouldn't flash. Now it flashes but in the closed position. I was hoping there was a simple fix for the inoperable catch so I didn't have to spend big bucks.
