Question about Dell Inspiron 6400 Notebook
I am using Dell Inspiron 6400 notebook. When ever I open screen, It giving GAP in right corner od screen, its keep on increasing and bit tight when opne screen. Please help to assist.
  • Dell Master
  • 32,281 Answers
The hinge is faulty and can be replaced.
For details on how to fix or replace the hinge - click on this WEB site :-
http://www.insidemylaptop.com/replace-broken-hinges-dell-latitude-c640-c540-laptop/
For parts check out these WEB sites :-
www.laptopparts.com.au/
www.laptopking.com/
www.laptoprepairparts.com/
Posted on Dec 03, 2009
    New Friend:
  • 23 Answers
SOURCE:
How to decrease volume
Your audio drivers should provide an icon in the lower right corner of your screen (normally). If you hover your mouse pointer over it, most of them will identify themselves. Once you have found it, there are a couple of different ways to proceed. Normally, a double click will open the volume control, since that is the most common use. Alternatively, you might right click on the item and select one of the "open" options from the pop-up menu. Usually that gives a more complete view with more options than just the volume control.
Dec 15, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
My dell inspiron 6400 screen goes upside down
the screen orientation can be adjusted, there should be a button combination similiar to CTRL+ALT+Arrow key of which direction you want to flip it to. or then you have to look on the bottom right corner of the screen for display adapter settings, there should be a orientation setting there if not, then right click on your desktop and select properties, then settings, then advanced. there go over all the pages and look for the orientation setting. That last advise if for windows xp.
Jun 07, 2009 | Dell Inspiron 6400 Notebook
Dark area on left side of screen of Dell Inspiron 1525
ok , i have had this problem on bolth my dell inspiron laptops , on a 6400 and a 1525 . the 6400 had the lower left corner all dark and the 1525 was split right down the center . i fix bolth of em in a really simple way , turn on ur pc and go into windows , press the blue Fn button and the down arrow untill ur brightness from ur backlight is completely down . keep it that way with the screen on with a screen saver for about one hour then turn brightness back up but not all the way up cuz in my case the problem hapened again , but when i keep it just one click darker , boom problem fixed . from what i can figuere out is that the inverter aint powerfull enought to power the backlight and tends to over heat , so keeping the backlight a bit lower tend the keep em ok
May 28, 2009 | Dell Inspiron 1525 Notebook
How toturn on wireless in dell inspiron 6400
you should have a key on keyboard in lower left corner by windows key that says"FN" then hit "F2" that should do it, if that is not the case then there should be a switch along the edge of machine
May 01, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 screen is fading
Sounds like the backlight is going out. Youĺl need to replace the LCD screen. You can find them on ebay. Just make sure you purchase the correct one for your laptop. You will need to take out the screen to see who makes it and the number. Go to dell.com/support to find your manual, if you feel like you can do it yourself.
Good Luck!
Apr 04, 2009 | Dell Inspiron 6400 Notebook
My dell inspiron 6400 right click dosent work
Go to control panel and Mouse settings. Make sure settings are set up correctly. Same place for the Touchpad.
Mar 07, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspiron 6400 is extremely dark. +brightness does nothing
Hi there.
Yes, if you can see a very faint image on the screen that indicates that the inverter or inverter coil has become defective and needs looking at or replacing.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Dell Inspiron 6400 Notebook
Inspiron screen wobble
image wobbling, or lcd wobblings, please?
Feb 28, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
191 people viewed this question
Clive
Clive
Alun Cox
