The grill has two and maybe three screws onthe under edge of it remove and lift up and tilt out / there is a spring holding it in place / remove and lif off .. do clean the condenser coil ( unplug or turn off power befre doing this ) vacuum the compressor area. you cannot lube the compressor as they are sealed .. the fan motor is generally the noisey . replace if so ./ clean both sides of cond and fan blades .. mm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
