Gateway GT4016 Desktop PC Logo
Posted on Dec 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GT4016 hit pwr button comes on flashes three
GT4016 hit pwr button comes on flashes three times on pwr button then pwrs off with fans still running. any suggestions?
Dave Sargent
Level 3:
  • Master 488 Answers
  • Posted on Dec 02, 2009
Dave Sargent
Master
Level 3:
Answers
488
Questions
Helped
170640
Points
1538
Check the USB ports for damaged contacts. If the supply powers up and then shuts down immediately, you have a critical error. Damaged USB port contacts can cause this but so can graphics cards etc. Open the machine up and remove all cards and memory sticks and unplug all the drives but LEAVE THE CPU ALONE!! Now, turn it on. If it boots and starts beeping ( which it will with no memory installed) shut it down and reinstall each item you removed one at a time and turn it on after each single thing. When it stops booting and does whats its doing now then the last thing you plugged back in is the issue.
If it still doesn't power up with everything removed then the issue is in the mainboard. If this is th case, my advice is to seek professional advice..
My ONN tv after three years went black and never came on again- onc50UB18co5 -when plugged into ac outlet - LED light comes on and can be powered off with remote, but after pressing power button on the...
verify that you have no image on all inputs. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, use a flashlight and angle it against the screen with the TV at a station where you can hear the sound See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
1helpful
Unit stays on for approx 13 min then pwrs off and i cannot pwr back on for awhile. please advise corrective action.
Either the humidity sensor is defective or there is possibly a thermal etc protection device that is malfunctioning.
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Gateway gt4016 desktop, s/n gcm64 110 54982 unit will not boot up, pressing power button, fans starts, yellow light comes on, then shuts down. cleared cmos, pressed power button unit will boot up but...
the cpu could be over heating make sure its secure if you like get some thermal paste from your local pc world put a little on the top of the cpu under the cpu fan and replace fan securely might work be carefull....bonnell
MY Gateway GT4016 Will not start anymore, i first replaced the power Suply and nothing happened. the fan runs and a light blinks then it shuts down again, i used to start it by just pressing the button and...
Make sure all fans are running power supply one to hehe Maybe a bad power button? I had a gateway that did some thing very close to that because the cpu fan was not turning and a hp that did that because the power supply fan was not turning. Thats where I would start then make sure the mem is seated good and not bad you know the drill ;) if you replaced the power supply with a factory replacment it should be a voltage or wattage problem. Might also try a hard boot the power plug take the cmos bat out hold the power button down for 20 or 30 secs some people say to leave the cmos bat out and try to fire it up. I know that works on some laptops but I always had better luck putting it back in for desktops cant hurt to try it. If you have two ram sticks in it pull the # 2 one and try to fire it up if nothing changes swap the # 2 one with # 1 leaveing slot 2 open and try it that will tell ya if it is a bad ram stick I dunno just my two cents hope it helps
The fan turns on but the little blue light doesn't when i hit the power button
Possible you need a new Video Card or your hard drive not working properly.
You need to be more clear in order for me to figure out what wrong with your computer.
GT4016 WILL NOT BUT UP. DOS NOT PAS POST
are you able to get display? if yes please check your hdd connections, if no then u need to get checked your motherboard
Gateway gt4016 won't boot. Fan runs but nothing
open cpu cabinet and pull Ram and refix it.
Aslo reattcha llconnection to mother bord.
Pull cmos cell for 15 minutes so all bios setings are set to defaults.
Sony KDF-55WF655 Won't Pwr up
There's a fan in the optical block (light engine) You may also have either an intermittent fan or a bad connection from the fan(s)
michtech
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
