Maytag gemini range; First I had the ignition spark clicking and would not stop then there was a burn-out smell and a little smoke and and then no spark to light burner gas still comes out but I need to light with match by hand. Could this be a burnt out spark module burnt and how to get add it/ What part do I need to replace? Many thanks!
SOURCE: Gemini Range Dual Burner
Unfortunately, you cannot repair one element of a dual burner. It all comes as one unit. When one portion of a dual or triple element goes bad, you must replace the whole element. I believe the part number is 1032746 and runs about $70. You will have to lift the glass top to access the burner elements. If you decide to pursue this on your own follow these steps: 1. Unplug range and/or turn off main breaker. 2. Open oven door to access screws under front edge of cooktop. Remove two screws and the top should tilt up. 3. The top will not stay up on it's own, so you will need some assistance holding it up. Some ranges have a couple of disconnect plugs that you can unplug, so you remove the entire top and lay it somewhere to work on. If this is the case with yours (as I suspect it is), lay some soft towels down on the kitchen table or counter top and lay the cooktop upside down. This will make it much easier to work on. 4. Remove affected element by disconnecting the wires first. You may want to write down how they came off, so you can be sure to reconnect them in the right order. 5. Remove mounting brackets holding element in place. Pay particular attention to the numbering scheme on the bottom of the element and where the brackets are mounted. The new element usually doesn't come with new brackets which means you have to take the brackets off the old element and put them on the new element. Make sure you install them in the same numbered holes as they were located before. 6. Reconnect wires and reinstall cooktop, making sure you reconnect the disconnect plugs if equipped. Now, be careful when working on the cooktop while it is upside down. Make sure you don't apply too much pressure on the glass or you could crack it. Also, use extreme care NOT to touch the element surface as the oils from you hands can cause hot spots and effectively ruin it. The bake light material in which the element is mounted is also very fragile. DO NOT put to much pressure on it or it may crack and break. Once you get the cooktop reinstalled and power reapplied, op test it to make sure BOTH elements are working. It is normal to see a little bit of sparking at first with new elements and/or an odor. Test the entire range of the element and make sure it regulates like it should. I hope this helps you.
SOURCE: Smoke pours from under the range top when a burner is on
[UPDATE} I gathered up the courage and left the element on for a while, carefully using aluminum foil in place of a drip pan. No bad smell. The initial odor was just the residual burning off of the last of the rust/dust. I was worried about directly contacting the hot element with the foil so I made sure it didn't directly touch the element but that was probably an unnecessary concern as aluminum foil has a very very high melting point
SOURCE: maytag gemini gas range--3 burners wont light,
Hi, there is a switch on each burner control knob shaft. These switches wear out and are easy to replace once you remove the panel over the knob area. Each switch has 2 wires plugged into it and costs around 5 to 10 dollars. Any switch causes all burner electrodes to spark. Good luck,
SOURCE: oven burner smokes
Right at the base of the burner is the air shutter and orifice. Tighten down the orifice with a good fitting wrench. then open the air shutter all the way for propane. Make sure the regulator is set for LP if this is LP and I am guessing it is. I happen to have a training video which shows how to: HERE
I have it on that page with them other interesting videos and I ain't no pc genous so you will have to find it on the page. sowwy. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Here
is a tip that I wrote that will help figure out why the burner spark
keeps on clicking...
Gas Range Repair Burners
Keep on Clicking
heatman101
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
