Iv been given loads of unlocking codes for my nokia 6300 thats locked on orange im in the uk the message after entering a code says canot undo resriction and then it says phone restricted so iv been told i may need to use a usb cable so how can i unlock my phone useing a cable can you help
After typing 3 times wrong code your phone is permanently locked
and you must use service lile www.unlockbb5.eu price is around 20gbp if you interested please contact me at [email protected]
Salut tou
E65 has gone off line error code 100134 how do i get it back on
Palmer25 not 5 codes but only 3, 5 was long time ago before bb5 come to the market.
The BB5 calculator requires a hardware reset and is not done via imei
You cannot use the * + 3 + send combination, that is for s60 phones. i have search for bb5 calculator but they can't also make a code for 6300..poor thing..
Hi.u have only 5 tries with the codes.after that only way to unlock phone is to use cables
there is a free software called bb5 calculator.its made by dejan
u can try it :)
good luck
It dinnen work
You only get 5 goes at entering the codes out of 7 that the calculator provides, for Sim restriction. You should start with number 7 ten if it didn't work go to number 1, 2, 3, then 4.
If your phone is completely blocked. Your only option is to try the service provider.
Or Maybe just maybe try this:
Try a reset:
First turn it OFF, take the SIM card out.
Press * 3 send at the same time, then turn phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
1 - Switch on your Nokia 6300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6300 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6300 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6300
it is blocked and i need a code to unblock it thankss
i have a nokia 6300b and it is locked to the fido network and i cant seem rto get it unlock ,, i need help>>>>>>>>>>>
I have Nokia 6300b Purchased from Fido Canada and it is locked, I'v tried many code it did not work, would somebody advice me with the right code so the phone can be usefull and not a junk!!!!!!!!!!!!!!
thanks in advance for your support
unlock from orange to02
