First turn off water then remove the wall board ,or paneling at least 12 in above tub lip .,Remove more if you can.The more room you have the easer it is to slide the new tub into place. Now you should be able to reach the tubs drains unsrcew or cut them out When you have the drains disconnected .pull any nails or screws from around the tub. Look at the path you have to take to get the tub out ,you'll probably have to remove the toilet tubspout or maybe even the lavitory.when your path is clear put a flat bar between a stud and the inside edge of the tub pry the tub up and out. You way have to move from one stud to another.When its off the wall on the inside edge see if you can pick the back end of the tub up.This should make it easier.Remove all the bad flooring .You will need some lumber now replace the floor joist or scab onto them (you will need 3 or 4 ft of good joist on eather end to scab onto.If the edges of the new floor board dont land on a floor joist simply nail aboard onto the side of the joist it needs to meet on level with the other joist.Where the front of the tub sits cut a hole out about 10x12 in center of hole14and1/2in for standard tub and off the wall in front of the tub 12 in.This will give you room for the tub shoe(thats the part the tub basket screws into) Sit tub on flat level surface and measure from the ground up to the inside edge of tub .Nail a 2x4 on the inside wall about 4 ft long off the floor as high as the edge of the tub.Take your time and get this right if you dont you will have to pull the tub back up after you've set it in place..If you have room you can put the waste and over flow on the tub follow the instructions on the package use pipe compound on threds and plumbers putty on the basket lip.If your not going to be able glue the trap after the tub is inSet the center of drain 14 1/2 in off inside wall and 1 1/2 off front wall .put tub into place front in first drop down the back and slide tub ont the board you nailed up earlier level it up dont add pitch the tub has pitch built into it takes screws or roofing nail securing tub to studs hook up the drain P.S.dont nail or screw through the tub instead nail or screw just above the top liof the lip fill the tub completly up .plug up the over flow When water gets to edge of tub lip look fore leaks then release stopper and finish looking for leaks . YOU HAVE A LOT TO DO! Good Luck!!
