Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
Posted on Jan 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
FreeAgent 500gig External - How to open case?
Just wondering if anyone can help me with this drive. I bought it 2 months ago and the other day it dropped on its side about half a foot and the usb connector inside the case just fell off and is now floating inside the hard case. Now i realise its just a normal 3.5inch HDD inside so i just want to open the case and use a SATA - USB adapter so i can still make use of it. Is there are special way of opening it? Ive taken the base off to reveal the only 2 screws which look like a phillips head but none will fit it. i can pry the side open a little but then im afraid it will just crack and bits of plastic will go flying.
Has anyone done it before or have any ideas?
Any help will be greatly appreciated
Ant
  • 4 more comments
  • toine8 Jan 16, 2008
    yeah but as far as i know i think the metal usb part itself has snapped off as its just floating,,, do u think it might be still attached??
    i think whats happened is, it literally just the metal usb housing that is soldered onto the adapater motherboard has come off, as i can see inside the hole and it all looks normal accept for the silver usb housing is missing so i cant plug it in,,, i dont think its still connected to anything by the look of it.... mmm maybe ill have to just try and open it,,, this screws are weird as they not torx screws,, but none of my jewlers screwdrivers will undo them,,,, do u have one of these drives?
  • toine8 Feb 12, 2008
    basically the screws were mounted at the bottom underneath the plastic on the foot of the case. i got them off then had to pry the case open, due to strong plastic clips. When i was inside i discovered that the usb mouting solder had just come off. So instead of trying to solder it back on the board, i just ordered a caddy online, for £11 which fits the 3.5 inch drive straight in with an internal fan and all. Its actually better quality too as its a strong metal case. so problem solved, and ill never buy a seagate drive again. Very average quality. Thanks for your help anyway
  • toine8 Feb 17, 2008
    best solution was exactly right, but i had to figure it out myself, cheers anyway
  • toine8 Feb 18, 2008
    yeah its a sata 500 gig
  • bremchandar Dec 15, 2008
    hey guys,
    i hate the seagate now for putting such a bad design of the USB just sticking out to the edge and the f**g thing came off when a strong air blew that away.. Now dont know how to get this going, I'm scared to solder it. I opened the box and took the hard disk away, but dont know how to connect this thing to the laptop and get it going.. Appreciate any help ..
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
11211
Points
I believe Seagate has a 5yr warranty with this drive. Why not have Seagate honor the warranty and have them repair or replace the drive?
Anonymous
Level 1:
New Friend:
  • Posted on Oct 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11211
Points
Hi, help me please!
My problem:
DIAGNOSTIC CODE B0D4A145
what is it? what can i do?
Anonymous
Level 1:
  • Posted on Sep 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
11211
Points
Thank you my friend.
I was able to open my FreeAgent 500 GB
My problem is that the USB port has broken away from the board.
I was thinking of soldering them back, however the soldering appears to be very fine.
The port has 3 pins on it. (is this right), if I look closely, there seems to be slot of 5 pins.
Could it be possible at 2 pins have broken and fallen inside the drive/casing?
A
Anonymous
The drive is a SATA
A
Anonymous
What kind of drive is in this case? Is it a SATA? Thx.
A
Anonymous
1. Remove the rubber feet
2. remove the screws from where the rubber feet were.
3. Remove the esata/usb base
4. remove the lower plastic cover
5. remove the tiny screws
6. remove the metal shield
7. remove the 3 base screws.
8. stick a standard screw driver into the lower holes and twist. One side panel will move, one will not. The removeable panel is the one with the logo that lights up. If you are looking at the drive from the back where the ports are, the panel is on the left.
9. Stick the screwdriver between the plastic of the panel that moves. this panel has 4 clips holding it on very tightly but it can be pryed off.
10. Once the panel is open, unplug the drive and remove it. It is in a metal free floating cage. Remove the rubber covers to reveal the screws.
11. Pry the two cage panels apart and the drive is free. There is no permanent damage to the case, so you should be able to mount another drive in it.
JP Services
Level 2:
Sergeant:
Champion:
  • Expert 310 Answers
  • Posted on Jan 16, 2008
JP Services
Expert
Level 2:
Sergeant:
Champion:
Answers
310
Questions
Helped
257149
Points
607
If your afraid of spliting the case I would go fishing persay. I would try to fish the usb out to the hole. I know that you cant get it thru the hole so, if you get a magnet or a pair of tweezers or what ever you can, to snap it back into place. I dont think its broken. that will give you some time to find the right tool for the screws. once you get the tool youll need a small pocket knife to pop the case apart. once your in the case youll want to modify it so the usb cant drop back in again I would wire it and hot glue it from inside
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
  • JP Services
    JP Services Jan 16, 2008
    yes i do . if not it will have a piece of the mother board with it
1helpful
I have an seagate freeagent 500gig external hardrive and it fell off the counter and the part that connects to the cable for transfer data snapped off from the drive. I wiped my laptop and now I can't get...
there is,open the 500gb external case and take out the hard drive. go to your nearest computer shop and pick up an empty external hard drive case for internal drives.make sure its a sata drive,get your hard drive and put it in and reconnect it to your computer. those cases run around 80 bucks to you may need to look online for one to get a better deal
My computer doesn't detect my FreeAgent Pro 750GB (seagate)!!!
Do not despair - check out the documentation on page 3 (you'll need Adobe Reader to open this PDF file):
http://www.seagate.com/support/freeagent/FA_Pro_15_QSG_US.pdf
Hope this helps
1helpful
2answers
What is/can I do about a ''corrupted partition''?
Supposedly is not RAW will coming out, right! Either NTFS or FAT32. You cannot open your drive unless it is back into original format.
All you have to do, if you have a knowledge on how to remove the hard disk inside the Seagate Box (Freeagent) and then transfer it to your CPU. This devices is just like an HDD Enclosure.
Hope i help you this. Add comments if you want more information about this.
If i am helpful please rate me.
Thank you.
Yboyandrei
I bought this Seagate Freeagent external hard drive less than a year ago and the other day when I plugged it in I came to the cold realization that it had overheated. There is a known problem with the...
Most of these external hard drives are just regular old 3.5" or 2.5" hard drives in some sexy looking enclosure. Hopefully just the power supply to the drive overheated and did not do any damage to your data.
Disconnect the unit from the mains (duh!) and carefully disassemble the unit until you can get at the drive itself. Disconnect the drive, and see if it is an EIDE or SATA drive. Again, the drive itself is going to look a lot like one your've seen inside your computer because in 99% of cases it is the same thing.
Purchase another external enclosure for the proper type of interface (SATA or EIDE), or , if there is room in the PC itself, actually install the drive in your PC as an auxiliary drive.
Data retrieved.
Voila!
6helpful
2answers
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Seagate FreeAgent Pro Desktop 250GB - no power
go get a external drive enclosure from computer supplier
compusa
best buy
circuitcity
Seagate FreeAgent Desk - "Drive cannot be modified"
I went into Disc Utility and partitioned the whole drive for Mac OSX. After that was done, I was able to write to the drive and copy over files.
Seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
Make freeagent deskot 250GB master hard drive
1) I greatly suggest against making ANY external HD your primary disk.
2) Not many computers support this.
3) The most likely method would involve reisntalling your OS (Windows/OS X) onto the drive.
4) I just noticed this thread is from three months ago... :P
2answers
No Power to External Hard Drive
Do you have access to a multimeter or voltmeter? If you do you can check the voltage coming out of the adapter and make sure it matches what the power adapter says it is. If it doesn't, then it is the power adapter. If it does, then it is the drive or enclosure.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
