check and clean the brush bearings located on each end most reasons that belts break is the brushes are binding from debris --others bad belt or old and dried out
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBayreasonably cheaply, but again good tools and DIY skills are required. Have a look atwww.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07.
DC07s have two drivebelts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar. You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws. If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBayreasonably cheaply, but again good tools and DIY skills are required. Have a look at www.dysonmedic.comwhich has some excellent info on dismantling and repairing a DC 07, but unless you have accessto such tools, and feel confident to tackle it, it's probably time to callDyson or a Vacuumrepairer.
This model has Brush Control The Brushbar can be turned off to protect rugs and delicate floors
You've either accidently turned the brushbar off or the belts broken
You don't need to replace the whole clutch, you can replace just the belt. You can get the clutch belt and the brush roll belt combo pack for the DC07 here:
The end caps of the brush assembly which contain the bearings are only a push fit onto the spindle (quite tight). Remove these and the brush bar will pass through the drive belt loop. To achieve this the belt has to be stretched slightly so care has to be taken not to over-stretch what might be a belt getting to the end of its life. When refitting the end caps do not forget to aline them properly so they fit into the sole plate recesses correctly.
I cannot see at the moment how to replace the drive belt on the DC 07 without significant dismantling (that will probably be my next job) I do not see the use of the Dyson tool you offered.
