Car Audio & Video Logo
Posted on Feb 05, 2018
Will the naxa nx-687 fit in my car? I have a '02
Will the naxa nx-687 car audio player fit in my car? I have a '02 Lexus IS300. I am looking to get a new unit since my player has broken. i currently purchased a Scosche pocket instillation kit from best buy model #LS2075B, and a TYTO-01 wiring harness. All i need is the Player.
5 Related Answers
KaeZoo
Brian Neathery
  • 156 Answers
  • Posted on Jul 30, 2007
SOURCE: KVT-729 car DVD player
The steering remote control input is for a wired remote control, or a third-party interface that allows you to adapt vehicle steering wheel controls to operate your deck. Your problem is the parking sensor wire. This is supposed to be connected to your vehicle's parking brake switch. It detects when the brake is set, and will prevent a picture from showing when it's not set. The intent is to prevent you from watching movies while the vehicle is in motion. If you can get a good look at the parking brake mechanism, you should be able to see the brake switch. Usually there's a single wire coming from the switch, which is built onto the parking brake mechanism. Connect your parking sensor wire to the wire coming from this switch.
Anonymous
  • 518 Answers
  • Posted on Mar 05, 2008
SOURCE: remote control codes for naxa tv model nx -524
You neglected to post the Remote's Make and Model. However, most Univ. remotes allow you to "Scan" the TV codes one at a time. You would do this and watch for the TV to turn off. when it does, you have the code and can store it.
Geno
Anonymous
  • 113 Answers
  • Posted on Mar 28, 2008
SOURCE: avh-p6600
similar but not exactly the same - for a dvd you must also connect a line to the parking brake wire that shows ground when engaged
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on May 26, 2008
SOURCE: I just bought a Naxa Digital Mp4 player, how do I install it and start downloading music
http://www.naxaelectronics.com/downloads.php
Anonymous
  • 640 Answers
  • Posted on May 29, 2008
SOURCE: Ground wire idiot problem
connect the black wires, thats your grounding circuit.
My earbuds dont fit the NAXA nx-104 mp3 player
Hello, Katie -
I have not yet found any information on a Naxa NX-104 MP3 player. What I have found is information on Naxa MP3 players with the model numbers NM followed by a number (but not 104.) Do you have the model number right?
The information I have found on the Naxa MP3 players is that they come with earphones. Did your MP3 player come with earphones when you purchased it? It should have, if you purchased it new.
I suggest you contact Naxa Customer Service directly and ask if you can purchase replacement earphones for your model of MP3 player. This is the link to the Naxa Electronics Contact Us web page:
http://www.naxa.com/contacts
Best wishes.
How do you set and turn clock display on naxa nx667
Naxa Electronics NX-667 Clock setting - Questions - Fixya
www.fixya.com > ... > Naxa Electronics > Naxa Electronics NX-667
Naxa Electronics NX-667, clock setting related issues. ... set up the clock time 1: press Source button to turn off unit 2: press Clock button to display clock 3: press ...
Naxa Electronics NX-667 Kd s35 manual - Questions - Fixya
...kd-s35 Press and hold SEL button. Press ^ button 3 times to display H (hour) turnvolume knob to change hour setting, press down 1 time to select M (minute) ...
General FAQs - Naxa.com
I LOST THE CHARGER/RECTIFYER. hOW CAN I GET A REPLACEMENT? AND A COPY OF THE MANUAL. BY THE WAY, MAY SAMPLE IS NX-381, NOT 382 BUT THE NEAREST FOUND IN YOUR LIST WAS NX-382
This should be the link to a manual for your player. Naxa Nx-382 manual. For a charger/power supply you can try an generic one from walmart or off the net. They come with different ends to fit many different devices, and have variable voltage settings also. See this one from iGo. iGo wall charger.
1helpful
I just installed my Naxa NX-670, and now when I attach the faceplate, nothing works.
If you run into this problem, be sure that all the fuses to the wiring leading from the battery to the radio are good, then be sure that the yellow wire is attached to the constant power source and the red wire is attached to the acc/ignition power source.
3helpful
2answers
How do i put movies on the NAXA NX-142?
The NAXA NX-142 came with a miniature CD you must use the CD to install the software called AMV converter to your computer. Then run the AMV converter with the NX-142 plugged into the USB port. You can then convert certain videos like WMV files into AMV files which can be automatically uploaded to the NX-142 be sure to choose to upload the videos into the MOVIED subdirectory to help keep things organized on the NX-142 The AMV converter will allow certain settings to be selected. The manual is helpful but the printing is so small that I can't read it even with glasses.
Good Luck
1helpful
Changing the theme on the Naxa NX-142
go to your local audio store they should be able to order you one or google what you need.
3answers
How to charge battery
I think it recharges by taking some power from the computer when it is connected. I also use a cell phone charger from the razor series of phone.
1helpful
4answers
Mp3 player naxa nx 124
I have found that mine looses it's memory due to a dead battery. I have to connect it to a pc, format the player just like you would format a usb thumb drive. When you power it back on, it will flash the memory and rebuild the play list. Sometimes, it will loose my music, but all I have to do is load them back out to the player. It's kinda a hassel, but I don't care because I change the songs on it on a regular basis anyway.
Top Naxa Electronics Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Naxa Electronics Car Audio and Video Expert? Answer questions, earn points and help others
