Question about Mitsubishi WS-55807 TV
My mitsubishi ws 55807 turns on alright but the blue, green and red color are on top of each other and makes every image look triple. This tv was a gift from a friend and we moved it a lot to take it upstairs... maybe that screwed up something. Hope you can help me
  • 566 Answers
You have a convergence problem, if it happened after you moved it around then its either broken solder joints around the convergence modules(stk392-110) or it is a physical problem.
You could take the front screen off and see if the mirror inside has shifted.Also take the front and rear covers and look inside for anything that might have moved or cracks near components mounted on heathsinks. hope this will help. Good luck
Posted on Dec 02, 2009
SOURCE:
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
The set has a bowed appearance and the 3 colors have seperated. I imagine the bulb(s) are going as it's a old set.
The arching of color can be adjusted on the color gun by slighty turning the screw on the gun Blue, Green, Red. This fixes the arching and or fade-blinking in and out of color. The gun on my 65" sony is inthe front of the set. Removing the front panel grants me access to this. You may have to access it from the back on your model. Looks like a small box with 3 screws ont he front. Hope that helps...
Jun 30, 2010 | Mitsubishi WS-55807 TV
High Definition--WS-55807
IF the MITS has 3 component inputs blue red yellow RCA jacks on the back then yes at 480 or 720p, you'll need to attach 2 audio cables for sound. If it has a HDMI input then absolutely.
please rate!
Mar 11, 2009 | Mitsubishi WS-55807 TV
Lines and blue screen on WS-55807 mitsubishi tv
Take your two front grills off ,try adjusting one of the 3 knobs for background color.
Feb 04, 2009 | Mitsubishi WS-55807 TV
GHOST/MULTIPLE IMAGES AND COLORS ON MITSUBISHI WS55807 PROJECTION TV
In the menu ,,under settings usally ther a convergenge option,,what it does is realine the colors,, that should do the trick,,if your tv has that ,,good luck
Oct 05, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Lost Picture
Sound like problem in convergance circuit - Replaced them with STK-392-570 and replaced the bad pico fuses
AAPCO Electronics
Austin, Texas
Feb 04, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807
You have a convergence problem, and the sooner you get the set into the shop the less it will cost you. It seems that you may only have bad or cold solder connections on the stk convergence ics. If you keep hitting it to fix it, its goingg to surge the parts then youll be looking at 300 bucks or more to repair. GET THAT SET IN ASAP. Good Luck
Jul 13, 2006 | Mitsubishi WS-55807 TV
Mitsubishi WS-55807 TV Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
