Hello, Bill -
I had an Epson Stylus CX5400, which I loved, until a little over a year and 3 months ago. The black foam piece which was on top of the print heads tore off. I found out it was not worth having the repair work done to replace the foam piece. The estimated cost of repair work was about equal the initial purchase price of the printer.
Sadly, based on information I found on CNet.com forums, printers manufactured today are not made to last "forever". Here is one statement which I found (dated 13 Nov 2005, but still valid) which I believe covers the issues:
(Quote)
Price
by though stazi / November 13, 2005
The root of the problem is the low price of inkjet printers these days. Same goes for computers and virtually everything else you buy.
Every commercial company is out to make a profit. When the product becomes commoditized -- like printers and computers -- competition is based largely on price. This means the profit the company is making per unit gets less and less, so they start looking for other ways to cut costs. Moving jobs to Mexico, then China when Mexico got to expensive, and now they're being moved to Vietnam, Nigeria, and other third world countries, because even China is getting too expensive. In addition, every corner that can possibly be cut on production usually will be cut. The quality of parts going into computers since someone started offering a sub-$2000 computer has plummeted along with the price of systems.
The very simple reality, is that the great deal you thought you got, wasn't so great after all. It's just taken until now for some of the non-monetary hidden costs to show up. This isn't to say you always get what you pay for, but typically higher end items will have higher margins on them, and be higher quality.
With inkjet printers, the printers themselves are sold at a loss usually. Printer companies make it up on the back end with inflated cartridge prices. But the printers are still constructed pretty poorly most of the time, so they will break down. Usually the cheapest route is to just buy cheap printers, and then get a new one once the supplied ink runs out. Inkjet printers aren't worth getting attached to.
(End quote)
Source:
https://www.cnet.com/forums/discussions/why-don-t-printers-last-136467/
Best wishes.
SOURCE: Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
SOURCE: Black ink print failure after cartridge replaced
The Edge, -Clean the electrical contacts on the printer where the cartridge connects with alcohol. After it dries clean the same contacts with a regular pink, non-abrasive pencil eraser making sure you remove all the debris when done. -Its also possible there is an air bubble preventing the flow of ink. You can try inserting a full cartridge of ink in the printer and letting it sit overnight then running a nozzle clean job or two. Another alternative if you have a syringe you may want to try gently forcing ink into it. If you?re really desperate you can try drilling a small hole into the cartridge to give gravity feeding a hand. BE WARNED the air hole will let ink flow pretty well and you run the chance of making a mess. Before you pull the cartridge out of the printer make sure you cover the hole with tape so the ink doesn?t make even more mess. -Check the cartridge alignment making sure the contacts are mating to the printer. -If it still doesn?t work I would try cleaning your nozzles. Even though I doubt you have clogged nozzles its worth a try because of the following: If you search the Internet you?ll find that this specific model is know for failing to print some or all colors after about 1 ½ to 2 years of use, even with Epson inks. Most of the posts I?ve seen blame it on clogged nozzles but I suspect a good number of them, like yours, have another explanation for their failure. Ink jet printers use resistors to create heat to create a bubble in the ink to eject it out of the nozzle (Bubble jet) or in the case of Epson, vibrating crystals push ink into and out of the nozzles (piezoelectric). We?ve already cleaned the electrical contacts and cleaned the nozzles so what remain are defective nozzles, short between the nozzle and the controller board or a defective controller board. Since the printer is only worth 1 or 2 hundred dollars repairs at a shop or buying these repair parts can easily exceed ½ its cost. Hope something here works for you, I just recently had to toss a great printer too. Let us know what happens and please don?t forget to rate the posting.
SOURCE: c43sx both lights on
If your PC is connecting to it normally (no connection errors), it sounds like you printer is having the service reset hardware problem. Try installing the EPSON reset software and check all counters and error codes.
Try this one which fixed mine:
http://www.ssclg.com/epsone.shtml
Good luck...
SOURCE: Epson cx5000 Ink Cartridge shows ink is running out after 2 8 x 10 prints.
IT IS POSSABLE THAT THE PRINT HEAD ARE DIRTY THEY HAHVE MATCHING BOARDS TO THE TONER CARTRIDGE BOARDS UNPLUG THE MACHINE AND CLEAN THE PRINT HEAD WITH ALCOHOL IF IT DOESN'T WORK THE BOARDS HAVE FAILED
JP
SOURCE: Printer will not print black, but will not let me replace black cartridge
Had the same problem but this worked for me. To force a cartridge change, press and hold down the PAPER FEED button for at least 5 seconds as suggested here:
http://esupport.epson-europe.com/ViewArticle.aspx?lng=en-GB&kbid=313630&data=qBjAbS6NcI3fNMgp8+fHGGs5vImpFwyM
I then changed the black cartridge, even though I hadn't used much ink from the old cartridge and the computer was showing it as three quarters full.
