to confirm check the Ohm draw on the temperature probe, i am not sure what is the correct one but you can check online at blodgett if probe okie then you will have an issue with the temp controller there possible the potentionmeter is worn out.....good luck
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
The "F0" fault code is indicating a shorted OFF key pad. A technician would determine if the problem is the Key panel or the Control board by disconnecting the ribbon connector and measuring the flat cable pins 13-14. It should be open and should measure between 100-150 ohms while pressing OFF key.
He would disconnect power to range before testing the key panel.
I recommend calling a service technician to diagnose and repair your range
I have a kenmore gas range with digital display that will let me increase the temperature up to 35 degrees f*. It says to press BAKE for 6 sec., then use the number pad to increase or decrease then press START. Hope this helps Don
f2 error means :------- 1. The oven temp has risen above 665F and the door is not locked or 2. The temp has risen above 965F with the door locked-------------if this happens you should check:----------- 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits 2. Check and replace oven temperature sensor if necessary keep updated,please do accept and rate the solution.thanks.
THE OVEN SWITCH IS BAD ITS STAYING CLOSED.FAIRLY EASY TO REPLACE AND NOT THAT EXPENSIVE.ANY APPLIANCE STORE CAN ORDER THE PART OR YOU CAN FIND IT ONLINE.
