Cooktops Logo
Posted on Dec 01, 2009
Kenmore elite 36'' glass top cook top beeps and displays eo 11
Its less than a year old and beeps and displays eo 11
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1317
Points
robb101
Level 1:
  • Contributor 6 Answers
  • Posted on Jan 15, 2019
robb101
Contributor
Level 1:
Answers
6
Questions
0
Helped
2565
Points
15
Error 11 Electrolux induction cooktop
You will need to consult a professional to have the following repaired:
1. Test flex cable betweenboards.2. Change right board.3. Change center board (on 36"models only).4. Change left board.
Jul 23, 2012 • Cooktops
1helpful
2answers
The whole stove exploded while preparing dinner. Please any idea what would cause this to happen. My husband was slightly injured. Glass was flying everywhere. The cook top is 10 years old and we purchased...
it sounds like you got a dead short under the glass top , it could be a wire that shorted or some type of bug that got into the elements , I would even open the top with out pulling the plug out of the wall ,if it is 10 years old mite not be worth fixing but it should be looked at before you decide Frank
2helpful
Glass top is scratched and discolored...can you replace just the glass top? Susan
GLASS MAINTOP ASSY
Part Number PS253905
price around $812.92
Replaced main glass cooking surface on cooktop
First, shut of the breaker to the cooktop.
Then removed two screws to release brackets holding cooktop down. Then lifted the cooktop out of the recess in the counter top and removed the screws around the outside of the glass top. Removed the old, cracked top, by unplugging from the motherboard.
Turned the new cooktop upside down on table and placed weather stripping around the entire underside outside edge (to keep spills from going under the cooktop and cushion the cooktop from the counter top.
Then plugged the new cooktop into the motherboard, replaced screws around outside edge, lowered the cooktop into the recess in the counter, and reinserted the two screws into the hold-down brackets.
Turned the breaker back on.
Note: Just need Screw drivers and 40 minutes of your time.
2answers
Kitchenaid 36" glass cooktop with small crack
A small crack, turns into a big crack, Short of ordering a new piece of glass, there is no "fix" sorry. YOu can continue to use it, but eventually it will run across the cook top, and then shatter the glass... Better be safe than sorry.
11 year old jenn air expressions cook top
gud day,for my sujjestion is replace the unit coz if u get the part is more expensive to new one.unless is we have a rewind the motor like in the phillipines thats more cheaper to the new one,11 years is enougth for ur usage, that my sujjestion
Error codes 10 12 16 on kenmore induction cooktop
We purchased a 36" elite model on ebay for our house we are building. I finally installed a year later only to have error codes 39 & 40. I completely dissasembled it and put it back together. No luck. However after much searching I found the service manual for the 36" Icon by Electrolux (same manufacturer as the Elite). The guts look mostly the same. Manual states your codes 10 16 12 are for defective key sensors. I found out that on my cooktop if I held a key for maybe 20 sec or more it would beep once - indicating the key was not defective.
Link for manual on web site appliancejunk. com is below
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=270
1helpful
STAIN ON CERAMIC COOK TOP
We have a new product that is odor less and non-toxic. $8.95 a bottle + shipping. Our web site will be up shortly: debrucepolish.com I'm Bruce, can be reached at 612-220-2236
1helpful
Old kenmore gas cooktop with griddle
If the knobs will not push down and turn, this indicates the gas valve stem has become contaminated with cooking debris. The only solution to this, would be to replace the gas valves. With the cooktop more than 10ys old, parts may be difficult to find. If you can find parts, they will probably be prohibitively expensive.
1helpful
3answers
Glass cooktop keeps cracking in same area
The cooktop box has a metal flange. Make sure the cooktop when dropped into the countertop is resting on ther metal flange and not the glass edge by itself. If it rests on the glass alone the weight will cause the glass to crack at some point in time.
Dec 20, 2007 • Cooktops
Top Kenmore Cooktops Experts
Kolbrun...
k24674
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
