Question about Sony Televison & Video
Can a Sony Videoscope XBR TV be separated into pieces to move?
We have a Sony Videoscope XBR TV model kp53xbr45 we need to move. We do not have a manual. It is so heavy, can it be separated into two pieces?
    New Friend:
We moved it in one piece.
Posted on Dec 03, 2009
6ya staff
SOURCE:
Sony videoscope xbr
would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Feb 25, 2014 | Televison & Video
My sony videoscope XBR tv has a pink picture and no control. Also nothing is in enlish.
the model listed is a very old set---parts may not be available----language can be selected in the menu but the pink may be a adjustment of the screens (controls) or a circuit problem.
Aug 26, 2012 | Sony KP-53XBR45 53" Rear Projection...
Can't turn off pip on sony XBR videoscope TV
Look on your TV remote and press the button clearly labled PIP or Picture-In-Picture and press that button over and over. It will cycle through all the PIP modes until it turns it off!
May 02, 2011 | Televison & Video
Manual for Sony videoscope XBR, model # KP-53xbr35
Hi csp,
Welcome to FixYa.
My name is John.
I will be assisting you with your issue.
You can get one here. www.manualsonline.com .
Thanks for choosing FixYa.
John
Jan 03, 2011 | Televison & Video
I have a Sony XBR KV-32XBR55 bought in 1992. It
Patty - if you still need these pieces, I have them. Email me at globalmktg@comcast.net either way to let me know.
Dec 04, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony Videoscope XBR 53
This is a convergence problem. Look in the back for a couple of large black ICs attached to a heatsnik. These should be marked STKxxx. These are the convergence ICs and either have bad connections or are defective. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. There may be other parts that need to be replaced as well. I'll look up your model to find the other parts to check. The convergence board as an assembly, I believe, is no longer available. The parts that you require are available.
Dan
Sep 18, 2008 | Televison & Video
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Televison & Video Logo
390 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
