I recently installed Windows 7 and my Boston BA745 speakers will not work. I'm looking for driver or other solutions.
1) Try the portable player test. Unplug the speakers from the computer
and plug them into the headphone output of a portable-type stereo
product. This test should produce sound. If it does the problem is most
likely in the soundcard, or in your internal volume settings. You should
contact your computer's support group for further help in those areas.
2) Is the green power light illuminated? If not, you could have one of
two possible causes. The first and less serious issue is that the power
supply is not outputting the correct voltage. You can test the power
supply with a voltage meter or you can always take the power supply to
any electronics store and have it checked there. If it is not outputting
the correct voltage (12VAC), contact our parts department for a new one
at (978) 538-5136.
If the power supply is working properly, then your problem is most
likely in the amplifier. In this case, we will need to fix your system
here, and you can contact customer service at the above phone number to
set this up.
3) If the system is connected properly and you have a green subwoofer
light, disconnect the power supply from the wall for 10 minutes. This is
a common problem on overloaded surge protectors. To many devices on the
same surge protector can limit available power. Putting your speaker
system on its own circuit (or a more dedicated one) should eliminate
this problem.
4) Check the bass level on the back of your subwoofer, (or on your desktop
control pod. For best subwoofer performance place the woofer on the
floor along a wall or better still in a corner. This "corner loading"
will increase bass output.
My BA745 Sub just stoped working. There is power just does not work, can I fix it. Take it apart and do something with it?
My Boston BA745 sub speaker stopped working also. The other speakers still work. Can this problem be fixed or should I get new speakers. Can you recommend a brand that gives excellent sound and quality at a price under $50.00. Please answer in plain English. I don't know computer slang.
