I just bought a new jensen deck and had it installed but the screen doesn't play video but the audio works when playing a dvd. The technician by passed e brake with a switch and he couldn't get it working.
Does your subs play when you are playing a cd?If yes then you need to check the turn on lead for your sub amp and make sure your jensen deck is putting 12 volt out when your dvd is playing.If it is not you need to find the correct amp turn on wire, if it is then you may have to re equilize your sound when you are playing dvds.
New player? Under warranty? Take it to whoever installed it. Sounds like a weak laser, or a laser alignment problem. Could also simply be a dirty laser lens, but proper cleaning requires disassembly (those laser cleaning discs are hit-n-miss, and I've seen them actually damage the laser pickup, so I do not recommend them).
Was this a burned dvd or a store bought one? Sounds like the laser that reads dvd is dirty, try to play another dvd and see what happens after cleaning.
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
1.bad rca jacks
2.could be connected to wrong audio lead rca jack
3.the settings in dvd player donot match the receivers example- dts or ntfs
4.make sure its regioned to your player some audio isnt on the disks
5.pc's usually have new cd formats that came out
cd's and dvd's for some reason in this age isnt being able to play fully in older equipment do to the change in cd/dvd formats which makes you go out and buy new equipment it happened to me not just 2 weeks ago bought a new dvd and found out it wouldnt play in my year old dvd deck had to go out and buy new dvd deck then disk and all my others played fine
