Toshiba Satellite 1135-S1553 Notebook Logo
Posted on Dec 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wireless I cant have access internet wireless. I don't know if I need any programs. Please help me. Thanks. Jameson Guedes
  • jamesonguede Dec 01, 2009
    Yes, the switch is on but light never tuns on.
Anonymous
Level 2:
Scholar:
  • Expert 166 Answers
  • Posted on Dec 01, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
166
Questions
Helped
46843
Points
350
Did you have it in the past? is your wireless adapter turned on? toshibas have a tiny switch someplace on the side of case. and the fn key combo also will turn off. make sure wireless light is on. if it is than card may be bad, if not than turn it on.
  • Anonymous Dec 01, 2009
    check your fn key combo and make sure its not off there, press fn key and at the top row you should see a key with a blue wireless symbol over it. if it still stays off than its prob a bad card. cheap and easy to replace
Westell 0738 Is my next door neighbors wireless point I can't acess her network it asks for a password..can I get around it? And is there a universal password?? She's old and I bet she don't...
There are no universal password/encryption setting.
Your next door neighbour has protected her wireless network and Internet access from unauthorized access. If she wishes to give you access to her wireless and Internet she would give you the password. That is her choice.
Cant connect to the internet..
Hi, What error do you get when connecting to the internet?
Anyways, Probably the Wireless connection your trying to connect to has a Network Security enabled on it.
Gaming consoles cant' access that type of Encryption, reason I do not know why but to be able to get wireless connection using your Nintendo DS you will need to disable the Wireless Network Security of your Wireless Router to be able to get Wireless Access using your Nintendo DS.
I also had issues with mine before and found out that disabling the Network Security will let me get Internet Access on my portable console.
Just Disable the Network Security this will allow you to get Internet Access on your Nintendo, for the Security of your Wireless you can get the MAC Address of each wireless device you have and input those MAC Addresses into the Router Settings to get Security and not allow other poeplt to gain access on your Wireless Internet.
I hope this Helps.
Have a nice day,
mvincentc
2helpful
Cant connect my sons nintendo 3ds to the internet
Hello. For setting up an internet connection with your Nintendo 3DS, you have to follow these easy steps:
1. Turn on your console and go to System Settings
2. Tap Internet Settings
3. Tap Connection Settings
4. Tap New Connection
5. Tap Manual Setup
6. Tap Search for Access Point (Here, your Nintendo will search for any wireless connections in range. You will see a status message: Access point found)
7. Look for a Wireless connection (if it's not yours, you have to know the password in order to acces other's connections) Every locked/unlocked connection has a lock/unlock icon. Acces the unlocked icon and then you are connected!
Note: If you didn't manage it / if you don't know your wireless security key / if you are not sure which wireless connection is yours or if you don't see any, please leave a REPLY.
I hope I helped!
1helpful
Hi, i just purcchased a wireless internet mod. from sprint, i have a willess for my xbox already, i got the internet up and running, but when i went to connect the wireless to pc so i could join xbox live...
I apologize but your description is a little confusing. You state you are trying to connect the xbox to the wireless connection through your PC?
If you are trying to connect your xbox to the internet through your wireless router but it ask for a WPA key, you will need to enter this key in order to gain internet access. If you do not know they key, you will need to access your router configuration page, log in and reset or generate the key.
You can do this by following the steps below.
Open up your internet browser on your PC and go to your gateway IP address. This will usually be 192.168.1.1. A log in window should come up and you will need to log in. Once you log in, there should be a section for wireless internet settings/security. You will be able to add the pass key or reset it.
If this is not your wireless internet connection(this is a neighbors internet) then they will have to give you the pass key.
Regards,
G33k
1helpful
I cant connect to the internet on my laptop i do have the wireless but cant connect to the internet
Press Fn +F5 key then turn on wifi. Also make sure wireless switch is turned on.Then check if sitll not connected then uninstall wireless network driver from add remove programs in control panel then reinstall. Then if you are able to connect wifi then still not access internet then follow below to configure wifi router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN setting and set as your internet service provider settings.Click on wireless and enable it if it is disable then save settings and restart router. Then check. . Let me know if you need further assistance. Thanks for using FixYa.
Cant access internet but can connect to wireless TP-link router
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer .
You said that you can connect to the wireless network but you can not go online.
Check the IP address and the default gateway of the computer.
Try to ping the router and DNS server and check what happens.
Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
2answers
Don't know how to set up home network with 2 computers
You can buy a linksys wireless router. that would be helpfull.
Thanks, PREM
2helpful
Accidentally deleted a program and now internet won't work
If you are unable to restore the previous settings of the computer? I might advised you to search for the driver of your wireless adapter and you'll needing to reinstall it to your computer.
Note: Make sure that the adapter is still installed to the computer.
No internet access with air card
Before you go to your friend's, download the Watcher program from Sierra wireless onto a cd. And install it instead of the AT&T Connection MGR.
For random disconnects and difficulties signing on with ATT Communications Manager
download the watcher program @
http://www.sierrawireless.com/support/
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Wireless connection
There are three major steps to setting up a wireless router.
First set up WAN side access to the internet. For this you need information about your internet service provider. Please respond with your internet service provider's name or better yet a link to their help/support website.
I assume you already have access to configure the router at 192.168.2.1 if not please do the following. Open Internet explorer and enter 192.168.2.1 where you would enter fixya.com and press enter -- do web pages appear in your screen from the wired computer. If so we have manual access to configure the router. If not let me know.
Please reply with a response to this message.
Second we will test wireless connections to the router
Third we will secure the tested wireless connections to the router.
This process will require interaction and several iterations of instructions to complete. Please add a comment to this request with the necessary information if you with to proceed in this fashion.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
