Question about Technics SL-1210 Turntable
On my Technics 1210 mk2 turntables everytime i press the stop button, they dont stop dead but start going in reverse. I have just replaced the pitches on them aswell. Any idea?
    New Friend:
  • 135 Answers
I suspect the "brake" adjustment has been badly adjusted - it will need correctly adjusting.
http://stores.ebay.co.uk/methleykev
Posted on Jul 19, 2010
SOURCE:
Technics 1210 mk2
As everything was normal before you started the work, I'm thinking you might have disturbed something. Such as caused a wiring plug to come loose. Maybe even a bad solder joint somewhere?
Apr 28, 2014 | Audio Players & Recorders
Technics sl1210 mk2 motor speed error
pls use the search function, this is answered 50 times
Jan 08, 2014 | Technics SL-1210 Turntable
He doesn't start anymore
I'm havin the same problem,
did u manage to work out what the fix is?
Dec 20, 2009 | Panasonic Technics SL-1210MK2 Turntable
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sep 07, 2009 | Technics SL-1210 Turntable
Turntables lags on pick up
I have the same exact problem with one of my 1210 MK2 turntables. It seems like the motor is too slow now. When I hit the start button or release the record, it takes much longer to speed up to the normal speed than my other same exact turntable. I don't think it has anything to do with the pitch slider. Please let me know if you find out what the problem is thanks!
Mar 18, 2009 | Panasonic Technics SL-1210MK2 Turntable
1210 mk 2 pitch
Doubt it, ive heard of this problem before, usually people buying them second hand and the answer has always been get them repaired professionally, i dont know the reason for them doing it sorry.
Jun 10, 2008 | Technics SL-1210 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Technics sl 1210 MK2 does not start
Your switch probably went bad. Does it not respond at all? Does the button at least 'bounce' back when you press it? If not, then you might have messed something up when putting it back together.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
1210 mk5g pitch adjustor
switch off for a will and see.
if still bad. check the circuit board under.
with old electronic devices, capacitors are commly the ones that may go wrong/dry. which would cause oscillatory circuit to generate wrong signals or strobe or feebacks. if you know how to take out the circuit board, check it starting from capacitors.
Jan 22, 2008 | Technics SL-1210M5G Turntable
Technics 1210 mk2 problem with pitch and lights
Check that your voltage settings are set correctly. This is located underneath your turntable platter. If you remove the slipmat, you will see 2 holes on the metal platter. Rotate the platter till you see the voltage switch, located @ the 9'o'clock position. Make sure it's set to your correct settings (N.America = 115V / Euro = 220V). If not, you will need a flat head screw driver to switch it. Before you switch it, make sure your unit is off and unplugged. After you swich it, it should be ok.
If your still having issues with the speed and the pop-up light, then there is something seriously wrong, and will need to be checked by a technician. Sometimes a resistor or IC will go bad, causing the speed issue, but for the pop-up light - that's usually faulty wiring generally caused by an incorrect replacement.
Did you buy this new or used? Have you had this serviced recently?
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Nov 30, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
245 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
