I called a local place and they said to remove the compressor panel and clean it. How in the heck to your remove the panel?
If condenser is clean, and everything seems to be working fine, most likely You will have a leak of freon(very slow usually) and 90% of the chance You will need to get quote to replace evaporator coils. Watch this video, might help to troubleshoot. Hope that helps.
Panel cover is spring loaded. Pull out the top and lift to remove.
