Question about Whirlpool Duet GHW9150P Front Load Washer
Error codes I have a Whirlpool Duet washer and for the past few days I have been getting error code F21 which I know is a drainage problem I readjusted the hose now I am getting f27 what does this mean?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 107 Answers
F27 = OVERFLOW CONDITION
Did you inspect the filter for clogs I have seen this happen many times The filter is located behind front lower panel and can be white in color follow the hoses its before the pump. I have seen the filter clogged and give these type of symptoms
but here is error code F27 out of the maintenance manual
If the overflow contact on the pressure switch is closed for more than
60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs
constantly, even if PAUSE/CANCEL is pressed twice and the display is
cleared. Turn off hot and cold water faucets and unplug the unit before
servicing.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch,
water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Posted on Dec 01, 2009
SOURCE:
Whirlpool duet steam washer error f21
The F21 code is a ' drain issue ' --- if you remove the bottom panel from the machine you will see the water pump right there,, just in front of the pump you will see a clean out area,, unscrew counter clockwise and remove the catch screen,,, it most likely has a few things in it ,, clean out - re-install and start the cycle. and the F21 code should be gone AND washer is back up and running.
Nov 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My duet front load washer has an F21 code. The washer does not drain. The manual says to check the drainage hose for a clog. I disconnected it and water runs freely through it. I'm still getting the...
Have you checked the filter, hose, and plumbing where drain hose goes to?
If you have and none of these are blocked then you have a faulty drain pump which will need replacing
Jan 27, 2011 | Whirlpool Duet WFW9550 Washer
F21 is flashing on the display
If this is a Whirlpool Duet series front loading washer, "F21" is a Long Drain error code. This is usually an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Mar 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F21 and cycle does not complete
If this is a Whirlpool Duet series front loading washer, "F21" is a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Feb 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Won't drain, screen display says F21
If this is a Whirlpool Duet series front loading washer, "F21" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system. Most commonly, there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Feb 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet HE washer/dryer. The washer keeps saying ''sud'' and we also get a ''F21'' error. The washer will not drain, and we are getting frustrated. Any idea on how to fix this?
If this is a Whirlpool Duet series washer, "F21" is a Long Drain error code. This may be an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
NOTE: The "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
Feb 12, 2010 | Washing Machines
We have a duet ht and it keeps giving us the f21 code how do we fix it
If this is a Whirlpool Duet, "F21" is a Long Drain error code. This may be an indication that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
Jan 12, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet washer getting a f21 code.sems water not empting
"F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
You may have something getting caught in the pump impeller and slowing it down. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUDS" error can commonly occur with the F21 error code as this is can be generated when air is sensed in the drainage system.
If the door won't open it could be jammed due to the program being interrupted.
If you have questions about this repair, or require additional assistance, please let me know. I hope this helps you.
NOTE: If replacing the drain pump is required, the following link explains how:
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
For troubleshooting guidance, the washer comes with a technical data sheet. It should be located behind the lower toe panel directly below the door. If not located behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes diagnostics procedures, troubleshooting tips and the error code list.
Nov 25, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Were is pump filter
The following link explains how to access the drain pump on a Whirlpool Duet front loader and clean it:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If you are experiencing problems with the washer draining and/or reocurring error codes of "F02", "SUD", or "F21", these are all indications of a drainage problem.
It does not take much to cause irreparable damage to the drain pump. If these preliminary measures do not correct the problem, you will need to replace the drain pump. Since any error codes are associated with drain times that exceed 8 minutes, if the pump is damaged in any way, these error codes will continue to occur until the pump is replaced.
NOTE: Double check the electrical connections to the pump, as well, by unplugging it and reseating it.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Oct 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,132 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
