Hi TH1754, you don?t mention your KA mixer model, but you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home). Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (for this example, I?ve used a KSM90P mixer) and select the last file listed that appears under Owners Manuals: KSM90PSWW0.pdf (2930.74 KB) and save that file to your PC. You?ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below: Beater to Bowl Clearance Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance Tilt-Head models ? Unplug mixer. ? Lift motor head. ? Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater. ? Make adjustment with flat beater, so it just clears surface of bowl. If you over adjust the screw, the bowl lock lever may not lock into place. I hope this helps! ?Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Let's try this again with the illustration...
Hi TH1754, you don’t mention your KA mixer model, but you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/p...). Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (for this example, I’ve used a KSM90P mixer) and select the last file listed that appears under Owners Manuals: KSM90PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
