Power does not come on anymore when power switch is pressed, however, progressive scan light flashes on and off.
SOURCE: Not able to turn off Progressive scan feature-sony dvp nc85h
Are you pressing the Progressive Scan button on the front of the Player? You need to look at the BACK of the Player. There is a manual switch just below the words "LINE OUT". This needs to be moved to the left where it says "Normal"
Try this please!
Brian
If it works like my sony RDR-GX315 just press the pause button on the player itself and hold for 5 seconds.
Press the "Menu" button. Turn the control dial and select "M."
Rotate the control dial and select "Prog. Scan." Press the control dial.
Rotate the control dial and select "Off." Press the control dial. The Progressive Scan LED light should go off.
