Xerox Phaser 8560 - What does this error code 09 037 45 108564 mean?
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
7,010.43:
The printhead is stuck in the tilted position or is not able to tilt forward to the print position, due to problems:
Has ink spilled ink around the printhead that prevents it from moving to its center position? You should be able to push the printhead right to left. Clean the printhead area. Is the printhead stuck to the Wiper Blade? Check the process drive gears for obstructions. Ensure the gears are correctly aligned and homed. Has ink spilled on the Head Tilt gear drive train? Clean the gears area of ink.
Has
Has
