Dell INSPIRON 6000 CENTRINO 1.7GHZ,512mb,40GB,DVDRW,XP (086216118098) PC Notebook Logo
Posted on Nov 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot open chm help file in my computer it show error massage
Anonymous
Level 3:
  • Master 532 Answers
  • Posted on Nov 30, 2009
Anonymous
Master
Level 3:
Answers
532
Questions
0
Helped
172148
Points
1592
Right click on the file. Choose Open With. Find the Microsoft Help program in the list and check the "always open this file with" check box.
File\minit\system32\Kdcom.dll could not be loaded.The error code is 4. The above massage is showing when I try to restore my Acer Aspire One.I am not able to run my window XP. Please help me.
It sounds like this file is corrupt you need to download a fresh copy and install it.
I would suggest trying to open your laptop in safe mode. While you are booting continually tap F8 and you should get a different menu. You need to select start in safe mode with networking. Follow the instructions to open it as an administrator.
When you have the system open use the internet to download a fresh copy of Kdcom.dll from here
http://www.dll-files.com/kdcom.zip?0WMmXCVMeO
Unzip the file to the same path as you show in your error message and overwrite the old copy of Kdcom.dll
Now restart your machine and hopefully this will have solved your problem.
32helpful
4answers
Unable to read massage 0 for update in tally ERP 9
Step 1
open drive where data is save
after it open your company data folder
than you have find a file (TMESSAGE.TSF)
it's error code 0
select this file and deleted its
after above process 100% your problem solve out
When start computer show this error massage software exception
ok sounjds liek the hdd has perotected itsself from loss mybe a check program boot i would ether redo the os or change the ram and see if that helps
I'm not able to find a manual for the Creative Muvo T 200 MP3.
Unfortunately, you won't be able to view the manual on your Mac without installing 3rd-party software.
You'll need to find a CHM viewer for your Mac. I can't guarantee this particular program will open the manual you downloaded from Creative, but there's a good chance it might.
Go here and scroll down to the xCHM for Mac OS folder. Download and install the latest version of the software. From that point, you can try to open it using the xCHM program.
If that doesn't work, you'll have to try to obtain access to a Windows XP computer and use the following instructions.
For viewing the guide to the Muvo T200 on a Windows XP machine, go to this page. Under "Getting Started," click on "Quick Start User Guide."
Click on "Download." There will be an "Agree" button. RIGHT-CLICK on that button, so that you can save the file (it is a file with a .CHM extension) to your computer. (Opening it at this point won't work).
The instructions on the site explain how to open the file. Here they are, for your convenience:
...follow these steps to view its contents successfully:
  • Save the manual on your computer.
  • Right-click the manual and select Properties.
  • Select the General tab, click the Unblock button, and then click OK.
The manual should display correctly when you open the file again.
Once I followed those instructions (going to the properties of the downloaded .CHM file and clicking on Unblock then APPLY), I was able to open and read the file in its entirety (meaning the links/chapters within the help file worked properly.) Try it a second time in case the file doesn't show the correct info the first time (it's what I had to do).
Here's the text from the first paragraph of the "How to use this manual" chapter that is beneath "Creative MuVo T200 User's Guide:"
"This document has been designed to provide you with complete product knowledge. You can resize the document window, print this document, access linked web sites and get information from specially prepared graphics."
Good Luck!
2answers
Error 2048 in QT
I think you should try this program.. I use it myself and I know it plays almost all video files:
http://www.videolan.org/vlc/download-macosx.html
PS: Please rate this solution
Activision Call of Duty 2
The msi.chm refers to the windows installer help documentation.Probably by any chance, the dvd is scratched making the that particular set of installation files unreadable. Try copying the disk contents to your hard drive prior to installation.Then make the installation from hard drive. There is no other solution because the Error itself is not clear.
Yahoo mail loggin error
reset your password in your set file
Nov 11, 2008 • Plumbing
Msi.chm\msdn
it seems that the file c:\programs\assets\movie\kurt\cs55sfd is corrupt or cannot be copied from the source
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
