Question about Whirlpool Duet GHW9150P Front Load Washer
My washer is out of balance when spinning.
My Whirlpool front load washer is out of balance when spinning. It makes a loud noise. How do I get the tub back in balance? GHW9200LQ is the model.
  • Whirlpool Master
  • 43,501 Answers
Your problem is probably much more than the washer being out of balance. The front load washers have shock absorbers that hold them from moving all over the place. These have a habit of breaking. Then the drum hammers and sounds like things are flying apart. Pull the bottom front off and check the shocks. Typically the rings where the pins go throuhg are where they will break. Sometimes at first they look okay and you have to grab them and move them to see that they are broken.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 30, 2009
Testimonial: "Thank you. I think this sounds like exactly the problem I'm having."
The door on my duet washer was open when I came to switch loads. The door won't latch now but washer turns on. Help!
Posted on Dec 23, 2009
2 Suggested Answers
SOURCE:
  • 1382 Answers
SOURCE: My Whirlpool front load washer is out of balance w...
Whirlpool front load washers have shock absorbers that helps them in moving the washer around the place. Due to regular usage of the washer it may tend to break.This will result in drum hammering sound . To clear this problem pull the bottom front off and check the shocks. Typically the rings where the pins go through are where they will break. You have to grab them and should have a complete check by moving them to see that whether they are broken.
Thank you !!
Posted on May 24, 2010
How do I fix a loud noise during the spin cycle in my whirlpool duet washer ghw9400plo?
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Aug 06, 2014 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
The tub is out of balance
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
May 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer balancing load, during spin cycle wasker shakes and walks
heatman101
Mar 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet WFW9400SW02 that is making loud noise during the high speed spin cycles. It is only 13 mos old. Whirlpool will not even stand behind the parts. The repair person estimates over...
Washer Problems
heatman101
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFS1276AW bangs loudly when rinsing and spinning
heatman101
Sep 06, 2010 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool washer making loud noise when spinning
It sounds like you need a bearing job. The bearings in the back half of the wash tub go bad. and the washer gets loud .It's an expensive repair. I hope this helps
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Thank you !!
May 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,998 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
