I am not familiar with your unit but It sounds like you may have more problems then you think. The freezer and refrigerator are probably on the same compressor so a fuse shouldn't be involved unless the light doesn't come on. If that is the case you have a tripped breaker or blown fuse in your house panel. Be sure the freezer is actually still working, they warm up much slower then the refrigerator. Put a thermometer inside close it and check every few hours for a few days. It will go up and down, this is normal but it should stay at least -10 or lower (guess on this unit). Check to see if the compressor is operating. Is it possible somebody bumped the thermostat while putting something in the unit?
Hope this helps as a starting point. Find a local source of dry ice in case the freezer fails, this will hold it for a while saving your food giving you time to effect a repair.
