I ASSUME YOU HAVE THE TC4002:
100 WATTS X2 @ 4 OHMS.
200 WATTS X2 @ 2 OHMS
400 WATTS X1 @ 4 OHMS BRIDGED.
LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
The mtx thunder is a 4 channel amp. 4 channels can't be bridged to 1 speaker. You can only use one side of that amp to bridge your speaker. Unfortunately your now only using half your amp.
Specifications
Power Output:
100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N
Signal-to-Noise Ratio:
80 dBA (reference: 1 W output)
Additional Power Output:
200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N 400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N
THD+N (Distortion):
<0.25% (reference: 1 W output)
Frequency Response:
20 Hz to 20 kHz (-3dB)
Maximum Input Signal:
5V
Maximum Sensitivity:
100mV
Dimensions:
14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
The recommended power range for you T4510-04 is 112.5 to 225 watts RMS. So you need a monoblock amp within that range. You could go up to about 300 watts RMS, but watch the gain and don't try to get too much from a single 10" sub.
The Orion Cobalt shown here would be a good match and is only $139.99. For another $60, the Alpine MRP-M500 will output 300 watts into 4 ohms.
disconnect the subs from the amp and check to see if the amp will turn on and stay on-check the subs to see if they are blown with a different source try a pair or a single sub that you know works fine on the amp and see if it plays-this should tell you whether your amp is fried or your subs are roasted
For maximum power, you'll need to wire the subs so that they present a 2 ohm load to the sub outputs on your amp. That will give you the full 420 watts RMS the amp is rated for. Likewise, you,ll want the run the front 4-channels at 2 ohms. Run separately, they produce 85 Watts times 4 channels, or if bridged, 130 watts times 2-channels. But if you run fronts at 4 ohms, they only produce 70 watts times 4 channels and your sub output at 4 ohms drops to 210 watts.
The red light is normal and indicates the amp is powered up. Check your signal wires (RCA patch cords?) and speaker wires. Need more info to be of more help. What receiver are you using? How is it connected to the amp?
