Question about Jacuzzi Amiga, Soaking Bathtub - 9180
Whirlpool bath won't turn on.
My Jacuzzi whirlpool bath won't turn on.
    Novelist:
  • 120 Answers
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Posted on Jan 20, 2010
4 Suggested Answers
SOURCE:
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
  • 80 Answers
SOURCE: Need User Manual
Go to Jacuzzi.com and plug in model and serial no. you should be able to find an operation manual there.
Posted on Aug 19, 2009
uspartscente
  • 719 Answers
SOURCE: jacuzzi whirlpool bath not working when i turn it
buzzing sounds tend to be a motor problem. You may need to change the pump. When you turn it on it just buzzes? that indicates a bad motor.
Posted on Dec 22, 2010
Need to purchase 2 front panels [white] for Luxura 530 jacuzzi whirlpool bath model N795 also, called skirts
Bath Panels can be very difficult to locate. I would check with your local Jacuzzi Showroom first.
If they are unable to locate the panels you need or they are no longer made then you should head over to Lowes or Home Depot to get a generic panel from one of them and you may need both panels replaced so they match.
rod
US parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
Oct 16, 2013 | Jacuzzi Home
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
I just bought a home that has a 3 year old white Jacuzzi Cetra H526 000 Whirlpool Jetted tub. It was not well maintained. I need 4 new Thermo Pro Jets, 2 Accu Pro Lumbar Jets, a square grille,and a product...
Jacuzzi Cetra Comfort Bath home page:
http://www.jacuzzi.com/baths/options/models/cetra
Installation and Operating Instructions:
http://www.jacuzzi.com/admin/files/files/4cfd8269-e7b0-4286-9908-7b9743.pdf
For replacement parts your best bet is to you use the on-line dealer locator:
http://www.jacuzzi.com/baths/pages/dealer-locator
or you can shop on-line from one of their authorized retailers; however did not see any of the parts you are looking for at the sites I checked:
http://www.jacuzzi.com/baths/pages/buy-online
Mar 17, 2011 | Jacuzzi Home
My Jacuzzi H522 will not turn off sometime without shutting the breaker off. It has even turn itself on a few times so we leave the power off
sounds like you need a new temp sensor on your tub. if it is not heating and running all the time even though it is calling for heat - then the sensor is bad.
you can find a sensor here Bath Parts Plus
Jan 22, 2011 | Jacuzzi Mito, 6 Whirlpool Bath - H522
Whirlpool jacuzzi jets not working properly
im not a great expert in this field but try putting some dish washer tablets in water when running to see if they can clean out anything,about 3/4 tabs
Mar 03, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Jacuzzi Amiga, Soaking Bathtub - 9180 Logo
3,112 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
