I just need to know how to ''USE'' the speed dial feature on my ''vtech 5.8 ghz'' i know how to prgram it. just cant use it. dont know how. HEEEELP! else: print:''youre screwed!'' lol.
Since you neglected to specify the model of your VTech 5.8GHz phone, I can only suggest you enter it into the search box here to download a copy of the manual.
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Programming Speed Dial Numbers The handset must be OFF. 1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode. 2. Press the number of the memory location you wish to store the number in (0-9). 3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL. 4. Press MEM to store the phone number to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing 1. Press PHONE to get a dial tone. 2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
For GE 6.0:There is a button on the base lower right corner (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:1. Pick up the phone handset and dial *98. 2. Press 2 to disable Do Not Disturb. 3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Remove transport/winding lever and loosen the retaining ring underneeth. Gently lift shutter speed dial and reseat it. Tighten the retaining ring and reattach winding lever. ( the shutter speed dial is not engaging the mechanism inside the camera and you need to establish proper connection ).
