Question about Sony VPL CS5 Multimedia Projector
Sony CS5 Wont turn on
Above projector wont turn on and the lamp/cover light is flashing even though we have changed the bulb and ensures all covers are closed,
any suggestions?
  • 27 Answers
The cover switch is probably not fully made.
Ensure that the cover tangs are pushing the pin
on the miniswitches.
Try putting slight pressure on the fan or lamp cover to see if the lamp/cover light
stops flashing.
you will need to do a restart on the PJ to check this out
Posted on Feb 26, 2008
RESTART PROBLEM IN sony svga vpl-cs5
Posted on Jun 24, 2009
6ya staff
SOURCE:
Turn off on screen message
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | Dell 4310WX Projector
Sony projector 3LCD lamp/cover blink red
When I plug the LCD the LAMP/COVER flsh blinking red light
May 28, 2012 | Sony Office Equipment & Supplies
I have a sony vpl-cs5 but is not turn in on, some body can help me, have a blinking led that say lap/cover.???
That could indicate the following-
1. The lamp cover or filter cover aren't properly closed. Try shutting the projector down> opening both covers> closing them> restart
2. The lamp is nearing the end of its life or is faulty and you'll need to replace it.
May 04, 2011 | Sony VPL CS5 Multimedia Projector
Lamp/cover light flashes
Did you replaced lamp in projector? if yes, please make sure lamp cover is fixed properly on its position. There is safety switch under lamp cover that needs to be pressed to turn off lamp cover light flash.
Thanks.
Oct 21, 2009 | Sony VPL PX31 Multimedia Projector
After installing the XL-2400 Lamp unit. This is the blub and housing. I turned the TV on and after a few moments the tv turned off and on the front of the tv where the power light is it is flashing red.
Please make sure lamp cover is reinstalled securely after replacement of lamp in TV.
If lamp cover is not fixed properly, TV wont power up and red light will start blinking.
Jul 16, 2009 | Sony (XL-2400) Projector Lamp for...
When the SONY VPL - ES1 projector is turned, the lamp cover opens , no light and after a while lamp cover closes. Mounted on the ceiling, it has happened after it was working well previously. Lamp has...
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Jun 11, 2009 | Sony VPL-ES1 Multimedia Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Lamp cover light flashes even with new lamp
Look closely by the cover there is a small sensor there, could be a pice of dirt and door not completely closing get a cleanpaint brush or little brush and clean area..Good Luck
Jun 25, 2008 | Sony VPL CS5 Multimedia Projector
It just wont turn on
Pls open the Lamp unit and check it if it is giving the power indication on the panel.
Viren
Nov 17, 2007 | Sony VPL CS5 Multimedia Projector
Sony VPL CS5 Multimedia Projector Problem
probably the lamp could be failing
or check the fan'lamp cover switches are being 'made'
Oct 17, 2007 | Sony VPL CS5 Multimedia Projector
Sony VPL CS5 Multimedia Projector Logo
1,232 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
