Panasonic PV-GS29 Mini DV Digital Camcorder Logo
Posted on Nov 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i get my videos from my panasonic camcorder to my PC, since there is no memory card, only a video tape?
Anonymous
Level 3:
  • Master 405 Answers
  • Posted on Nov 30, 2009
Anonymous
Master
Level 3:
Answers
405
Questions
Helped
233902
Points
1272
You can connect camcorder to the PC by fireiwre (IEEE1394), if you don't have firewire controller on PC, you can buy one. It is not expensive and usually comes with the cable.
2answers
No memory card for the Panasonic NV-GS10 camcorder...
The NV-GS10 uses MiniDV tapes. You should be able to buy these at just about any camera, department, or electronics store.
How to transfer sony dcr-hc26 videos to pc using usb cable thanks
The Sony HDR-HC26 is a miniDV tape based camcorder. No surprises if you can't get USB streaming working.
ALL miniDV tape based camcorders transfer DV-format video by conneting the DV port of the HD camcorder to the Firewire port of your computer. USB won't work. The "DV" in miniDV = Digital Video. It is as digital as the digital video from flash memory or hard disc drive or DVD based camcorders - only better because it is not compressed as much as the others.
Memory cards are not the only way to store digital video - and while not as good as miniDV tape, memory cards are not as bad as DVD based consumer camcorders...
Firewire IEEE1394, DV and i.LINK are all the same thing.
If your computer does not have a firewire port, hopefully it has an available expansion slot (PCI for desktops; PCMCIA or ExpressCard for laptops), so you can add one.
Transfer from pz card shot on HD to mini DV tape
you can transfer to DV tape only by using software like Edius 6 or a similar one.
First you download the p2 card on the hard drive and then you use this program to convert the video file to DV and use the camcorder as recorder connecting to pc via firewire .
Panasonic PVGS-50D SD memory card
Check your manual for the max supported SD card size. Most likely it will either support a minimum of 2-4 gb :)
So yes you can get larger cards for your PV GS 50D
Regards,
Shadowmaru
Importing camcorder videos from tape to pc
what cable are you using to connect your camcorder to the pc? and did you try to look at the manual for that situation. see also the settings from your camcorder before you connect it and look for the memory storage use or tape usage so that the appearance on the computer will be tape and not the memory card. can you pls give me some specific problems and details so that its not hard for us to solve your problem.
Needs
1.Cables like usb or firewire
2. installer cd camed from your camcorder
3. uploading software such as ulead movie director or movie maker, Windows moviemaker, Nero movie maker etc.. or whatever software you have.
4. Edit and save
the following steps are needed to transfer your videos to your computer.
tell me what you have.
CHARCOIS
4answers
Detect
you cannot get video off the tape with a USB cable, you have to use FIREWIRE
Help
The memory card is strictly for still photos. The tape is strictly for video. Transferring video tot he PC requires a firewire card on your PC (for direct cable connection).
3answers
Transfer of video from Panasonic NV-GS50 tape to computer
You can only transfer from the card to a PC. You can record video on the card in .mpeg4 format.
1helpful
How do I transfer video and stills to my computer?
Palmcorder Digital Camcorders offer you three easy ways to transfer images to a compatible PC2. * i.Link Lets you connect your camcorder to a PC for advanced viewing and editing purposes3. This digital technology also lets you connect your camcorder to a similarly equipped camcorder to make duplicate copies of your recordings with practically no loss of picture quality. * CARD LINK SD Memory Cards offer a simple, lightweight way to transfer your images to a PC4. It even lets you create images on your PC to use while you shoot videos with your camcorder. This revolutionary medium is included on all models with the CARD LINK function. * DV Studio This convenient feature allows you to link the camcorder to your computer via the USB port. Then, you can easily transfer still images captured on Mini DV tape to your computer4 for use in e-mail or printed documents. Please Note: 3-Way PC Link features may or may not be compatible with other operating systems.
Top Panasonic Video Cameras Experts
NOEL
NOEL
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
