Question about E-Machines T6520 PC Desktop
Have rs480m motherboard need the 2pin sequence to hook up the hard drive ''e-machine t6520''
  • E-Machines Master
  • 32,281 Answers
I assume you are looking to connect another hard drive in your computer.
Most desktop computers have two IDE controllers.
The 1st controller will have the "C" drive set to Master (MA) and there maybe another drive CD or DVD drive on the same IDE cable, if so the drive will be set to Slave (SL) or if you intend to install a drive on this cable.
The 2nd. IDE controller and cable can have hard drive or CD/DVD drives too but the drives must be set to either Master or Slave - BOTH drives in the one cable CANNOT be set the same.
Most CD/DVD drives have a label showing the jumper setting for Master (MA), Slave (SL)and Cable Select (CS).
You only need a single jumper and it is inserted in a vertical position.
There are a group of 6 pins (3 columns of 2 pins) next to the 40 pin IDE connector.
The Slave setting is usually the middle set of pins.
Posted on Nov 29, 2009
    New Friend:
  • 20 Answers
That Motherboard uses Serial ATA hard drives and CD players. One plug comes from the power supply and the other from the motherboard. They only fit one way. Since the fittings are different sizes and L-Shaped, you cannot go wrong. If in doubt, check the CD player connections.
SOURCE:
Need a sm bus controller driver
You can download the sm bus and device drivers from MSI WEB supportsite, select your model motherboard to download :-http://www.msi.com/index.php?func=downloadindex
May 22, 2012 | eMachines T6410 Driver Recovery Restore Cd...
Looking for manual for rs480m motherboard
Try this one:
http://productsmanuals.com/computer-manuals/ecs-rs480-m-motherboard-manual
Feb 16, 2012 | FIC AU13 Chameleon Motherboard
I need the diagram for the motherboard that is installed on my emachines model t6520. Do you know where I will be able to find one?
I Goggled your model and came up with this website: http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T6520
Jan 04, 2011 | E-Machines eMachines Desktop PC
I NEED TO KNOW HOW TO CONNECT THE POWER SUPPLY FOR AN EMACHINES T1120 COMPUTER. CANNOT FIND A SCHEMATICS DIAGRAM ANYWHERE.
After reading an article about Emachines awhile back, I found out the reason you can't find the schematic- it isn't available, as some motherboards are made specifically for Emachines and therefore not distributed, as they might normally be, but again, others are, but you have to identify them and go through another source to get them- Emachines, appartantly, will not supply them. All is not lost, however...all motherboards have, basically, the same hookups and connectors for the power supplies, hard drives, etc.- they are standard. I found a web blog that explains the power switch, reset, and power led, which will help. Here it is: http://www.computing.net/answers/hardware/emachine-power-sitch-wiring/56545.html
This site will explain about the 24 pin connector from the power supply
http://www.tomshardware.com/forum/53750-7-installation-manual-rs480m-w3400-emachine-motherboard
If you google "motherboard wiring" you will find sites that have illustrations of the motherboard, and explain which connectors go to which sockets, and how to identify them.
With a little patience and determination, you should be able to hook everything up from the various blogs on the net. Hope this helps.
Apr 17, 2010 | E-Machines eMachines Desktop PC
Need to re-attach power button cable, hard drive
The manual for your computer is available from emachines, p.168 shows the info you need (replacing the front I/O panel)
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
The good news is that you can't harm the computer by connecting the wires wrong and the bad news is they just won't work the way they are supposed too if not connected properly. The LED's must have the correct polarity to work.
In general, if you look real close (as in magnifying glass and flash light) you will see the ID for each set of pins is printed on the motherboard (pwr,rst,HDD,pwr sw,speaker) Just match what it says on the motherboard to what it says on the wires. Don't worry if you get the polarity wrong. If a light doesn't work just swap the two wires. The colored wires should be positve (+), though. The reset (rst) and power switch (pwr sw) wires don't require polarity.
These instructions are for most computers in general, YMMV.
Nov 30, 2009 | E-Machines eMachines Desktop PC
Blue LED light connection from Bezel to Motherboard
red white is the pair that supplies power it should be 2pin socket on motherboard
Sep 19, 2009 | E-Machines T6520 PC Desktop
I have a emachine T6520 that I'm trying to get to work.When I put in the recovery disk it freezes during the reconfiguring. What can I do?
Maybe you should try to do a "destructive" restore. when restoring from the recovery disc, you have the option to do a "destructive" or "none destructive" system recovery. if you choose to to non destructive recovery, then any virus that may be on your pc will not be removed and this may be the reason why your recovery always stops half way through. note that this will format the hard drive and you will loose all the files on the hard drive, including photos and documents. if this doesn't work then you should try to find out if you have a hardware problem. you can download one diagnostic software from seagate, that you burn to a cd. you use this as a boot disc, like the recovery disc, to test your hard drive, memory and motherboard to see if you need to replace any components. the most common problem is the hard drive. http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
Jul 19, 2009 | E-Machines T6520 PC Desktop
Hdd led off
see to the front panel section on mother board possibly on the right hand side of bottom u can see the label there to connect hdd led
Dec 28, 2008 | MSI RS480M-IL (816909008517) Motherboard
E-Machines T6520 PC Desktop Logo
149 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
