I recently got a 4 gig micro sd card for my Samsung gravity phone! I ''moved'' all of my pictures (65 or so) to the memory card instead of copying. They're not showing in the memory and when I go to copy pictures into it, it says it's full now. What did I do and where did my pictures go?
It sounds like the file format of the pictures does not show up in your device. If it has settings to let you see "all" files, then they will show up. If you have a computer what is on the sd card will show up there. That will also tell you the file format of the pictures. You could also change the format to one that can be used by whatever device you want to view them in, using photo editing software.
SOURCE: Sansa c250 sd card installation
yes i have the same problem how do i get the music onto card itself
SOURCE: G600 SD Card Support
Firstly, ensure that the memory card is correctly slotted in fully until you hear a faint click. [the card can be removed by simply pressing/clicking it back out again]. the memory card icon should appear at the very top of the phone's screen.
In the event that you have done that, to save files to the memory card, go to:
Menu;
Settings;
Memory Settings;
Default Memory;
Then select which items you wish to be saved to the memory card in future;
For example, select 'Camera', then scroll down to and select 'memory card', and press save.
Do this for each form of media, from the 'default memory' list, that you wish to save to the memory card.
Hope it helps!
SOURCE: my 8g micro SD card only finds 104kb of memory
The Samsung Gravity doesn't support the Micro SD HC (High Capacity) cards, just the regular Micro SD cards. Yes, it sucks.
SOURCE: not recognizing micro sd memory card
the M2 card used in this phone is little expensive but SD card will not work for sure.
Also the cheap M2 cards have problems of saving images to un-readable format.
make sure you use sony original or Sandisk card which i've seen working fine on this model.
SOURCE: change in sdhc memory card capacity
Go to the scandisk website and get the format tool.
If you got this card for something besides computer,you use the devise to format card and not the computer. Ex-phone.
Format card with phone.
If you got this for computer,you should have gotten a flash drive.
