SanDisk Sansa c240 MP3 Player Logo
Posted on Jan 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SanDisk CD Received a new Sansa c240 MP3 player....to start, inserted CD and my computer will not accept as an additional drive...what am I doing wrong...Please note, I'm computer illiterate...Thanks for your help...oh, did call Sansa tech support with no results...Marge
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 322 Answers
  • Posted on Jan 23, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
322
Questions
Helped
167633
Points
546
Are you using a usb conection ? or a lead ?
1helpful
How to Add 16G Micro sd card to Sansa c240 MP3 player?
is that mp3 player have the facility to add memmory card... then see in the side of the player their will an space given to insert that mcardf
1helpful
My Sandisk sansa c240 will not show up on my
you will need to install the computer drives for that devise and also you will need to plug it in to the usb port of the computer
Not charging
Try connecting directly to USB port on your computer, NOT a hub. It needs power to charge.
How to I start the c240 up it My computer doesnt
On Windows XP, when you open My Computer, the Sansa C240 shows up at the bottom, under "Other". Because of DRM restrictions, you cannot copy media files to the C240 using Windows Explorer. You have to use Windows Media Player to sync playlists to the C240 (WinAmp can do it also).
I also suggest that you check out RockBox. It's an alternative operating system for portable media players and they have a version for the Sansa C240. It will give you some additional functionality.
As far as I can tell, to copy files to the microSD card (if you're using one) you have to use a media card reader, then insert the card into the C240.
2answers
Cannot see music files on my comp
try connecting it to another computer to sort out the problem is between your computer and player
My sansa c240 is always freeze
hey u keep pressing the on/off button for a while then again insert ur sansa in usb port of ur comp ... it started working for me after that !!!
SanDisk Sansa c240
The photo files that aren't showing up don't meet the specification in some way or another - they aren't jpeg, the resolution is wrong, or the file size is wrong. Transferring music files from card in mp3 player to computer may not be possible - connect mp3 player to computer, double-click my computer, and open photos folder or any other folder that looks relevant - see if the said photo files are in there. If not, then you are out of luck.
1helpful
My sandisk c240 charges when plugged in but fails to be recognized on the computer
There is quite possibly a problem with the USB cable or the USB port on the computer, but try this shortcut force to force the computer to recognize the Mp3 player: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Sandisk Sansa c240 MP3 Player
Its real easy. Open the Sandisk from "My Computer" then just copy the songs from there. Similar with Copy and Paste from one file to another. Click CTRL C to the file you want to copy then put it inside the Sandisk folder CTRL V. That should do it!
What do I do with this "mini disc" supplied with the Sansa MP3 M240player. It is too small to insert on my computer???
Did you look at your CD player's tray? Most have an indented area in the center that accepts mini-disks.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
