SOURCE: Siemens Speedstream 4100 Modem installion
As you are using speed stream 4100 modem and it has a5 lights, if u have a 1 solid light for power and other all the 4 lights are flashing, It indicates either u need to upgrade the firware of modem or you may try Hard reset option of modem..At the rear sode of modem you will have a reset hole / button, u may press that using some paper clip...unplu all the cables and wait for 2 mins...connect them back in..all the lights will come up but the internet..u need to check IP address by doing IPCONFIG, whatever gateway u r getting (probably 192.168.1.1) type that into adressbar of IE and putthe correct user name and password, asked code u may get from the bottom side of ur modem...get into GUI og modem and put your complete email address and password, save settings ...Ok and restart the modem...it will be ready to go.
SOURCE: Siemens Speedstream 4100 Modem manual installion
* You dont need any special drivers to install modem.
* Open up internet explorer, type 192.168.0.1 in the address bar and press enter key.
* Now you should see the configuration page of modem.
* On the left side, click on Advanced button, below that, you will see "connection configuration" option - click on it.
*** If it asks for modem access code anywhere, you can find the code underneath the modem. please type it ***
* Under this page, you have to enter the email address in username field and password, change the connection type to smart keep alive, click on save changes
* Now it may ask you for restart modem. click on restart. within 1 min, you will be connected to internet.
Take care
SOURCE: Siemens SpeedStream 6520 Wireless problems! please help
um not sure, but if you have the disk that came with your router run it and fill in the wireless wizard. Also, on my 6520 the "wireless" led doesnt light up unless i have a device connected that is wireless. Your laptop may be incorrectly setup
SOURCE: how to setup/configure simens modem
hi ,
speed stream modem are really very good modem...
now we need to configure the modem ..its really simple ...
*pull the gui of the modem i.e. open the internet explorer page and in the address bar erase every thing and type in 192.168.0.1 and hit enter
*the speed stream (SS) page would open
*on the left hand side .. click on the login ....it will ask u ..ur user name and the password ..
the user name would be the email address provided to u by the company from where u got the connection...type that in and press connect ...
*there is one other way as well ...on the left hand side click on the advanced ..then click on the connection configuration...it may ask u about the MODEM ACCESS CODE...if it ask u abt that then flip the modem upside down and there would be probally a yellow colour sticker and on that sticker there would be a ten digit code .. type that in and click continue ...
*u would be on the warning page ..it will ask u abt the user name and password and retype password ...type the information ...at the bottom click on the save settings .. it will now ask to restart ..click restart...and u will be connected to the internet .. close the page once done
