Question about Casio JF-100TE Calculator
CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR
CHANGE TAX %+ & TAX- ON MY CASIO JF-100TE CALCULATOR?
  • Anonymous Mar 12, 2014
    change ribbon
  • Anonymous Mar 18, 2014
    I need to clear the register each day and still get a month end tape for tax purposes. How can I do that?
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Posted on Jan 26, 2008
SOURCE:
How to disable auto power off
You can't. When you think it is going to shut itself off, press some key.
Jan 28, 2014 | Casio JF-100TE Calculator
Change tax rate on casio jf-100ms
Press AC press and hold [RATE SET] for two seconds, "SET" will appear on left of screen. Press TAX+, type in the new tax rate, press and hold [RATE SET] for two seconds, then press AC.
Jan 09, 2014 | Casio Office Equipment & Supplies
How to set the tax on a Casio HR-100TE calculator
To set the tax rate, follow the steps below.
  1. Put the Casio in 'Print mode'
  2. Press the 'CA' button
  3. Press and hold the 'Set/%' button for about 3 seconds
  4. Enter the Tax rate
  5. Press the 'Tax+' button
  6. Press the 'Set/%' button
Hope this helps.
May 20, 2011 | Computers & Internet
How do i set the euro conversion rate on my casio jf-120ter caclulcator
Already answered here: http://www.fixya.com/support/t292440-casio_jf_120er_euro_rate_set
Mar 23, 2010 | Casio JF-100TE Calculator
Casio JF-100TE Battery Replacement
Taking the back off The Casio JF-100 calculator is similar to the ...TE. Remove the two screws at the top back. Place a small screwdriver blade along the seam where the back plate fits into the front plate. There are 3 fasteners on each long side and 1 fastener on each of the front and back sides. Find the spot where it's the easiest to separate the back plate from the top plate (there are only two). Carefully twist the blade to cause an opening. Then proceed sequentially around the perimeter releasing each fastener. The front plate will easily separate from the back plate at this time. There are no parts that will fall-out--don't worry. Replace the battery. Press the front and back plates together to snap the fasteners.
Jan 22, 2009 | Casio JF-100TE Calculator
How do you turn off this calculator.
It is solar powred and will turn off by itself. Don't worry it doesn't cost anything.
Sep 06, 2008 | Casio JF-100TE Calculator
Casio jf-120er euro rate set
Press AS
Hold Down RATE SET (%) for about 2 second and the correnty rate appears on the display
Imput the conversion rate and the press rate set (%) to store it in memory.
Best regards
Alberto
Dec 10, 2007 | Office Equipment & Supplies
Calculating percentages
Type 100 x 20%, and then hit the minus button
Dec 05, 2007 | Casio Office Equipment & Supplies
Programming the Casio HR-100TE
Printing models (except HR-8TE): 1. Have calculator in ?print? mode 2. Press [CA] 3. Hold [SET/%] key for about 3 seconds 4. Input the tax rate 5. Press [TAX+] 6. Press [SET/%]
May 21, 2007 | Casio HR-100TEPlus Calculator
Tax Rate
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 6 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 6 should be displayed
Dec 21, 2006 | Casio JF-100TE Calculator
Casio JF-100TE Calculator Logo
4,672 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
