just copy your contacts or move your contacts from your phone memory to sim card memory from Contacts setting menu. and paste it on any other IOS or android drive and import contacts. then again put your sim card in flip phone and first empty the sim card memory and repeat the same procedure;
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted. 2. Turn off mobile phone 3. Remove battery 4. Remove memory card 5. Remove sim card 6. Check the copper pins of the sim if there are dirts stucked on it 7. Ure clean cloth to wipe sim gently 8. Wait for at least two minutes 9. Gently and properly insert the memory and sim card 10. Insert the battery 11. Turn on mobile phone 13. Check if you will still recieve insert sim error 14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Unfortunately, the nokia C3 does not support the copying of contacts to the memory card and vice-versa. You can only copy contacts between the SIM and phone memories. You can do this by highlighting the contact you want to copy and selecting the options then more button. This would ask you if you want to copy to the other memory. Hope this helped you?
The LG Shine will only save messages to the SIM card after the internal phone memory is full (150 messages). This all happens automatically, and as far as I can tell, there is no way to force the phone to choose. Also, note that the SIM card will only store 30 messages. You can select the options menu
You can copy all your contacts in the sim card by going to contacts -> settings -> and copy all the contacts to your sim. Other information or data can be copied to memory card only.
The LG Shine allows you to do a multiple picture DELETE - but not a multiple pic transfer to memory card, at least that I've found. You have to transfer your pics one at a time from phone memory to the SD card as follows:
Select Menu --> 8 My Stuff --> 4 Pictures Highlight the pic you want to transfer using the center toggle button, then select Options --> 5 Move (or 4 Copy) --> 2 Memory Card --> Paste
Once your pics are on the memory card then put the phone into USB mode by selecting Menu --> 9 Settings --> 7 Connection --> 2 USB Connection Mode --> 2 Mass Storage
Then attach a suitable USB cable to the phone at the charging jack and open Explorer (Windows) or Finder(Mac) and navigate to the phone. Your pictures will appear and you can copy them to your computer as needed.
NOTE: be sure to return the phone from Mass Storage mode to Data Service or your phone will not work.
Also - set your phone to highest resolution for best quality pics. Menu --> 8 My Stuff --> 7 Camera and Recordings --> 1 Take Photo --> Options --> 4 Resolution --> 1 1600x1200
All you need to do is change it so its either.. the contact is a SIM contact or.. umm ... i can't remember the name .. its under options but you can change it! I have the phone but right now mine has a broken L C D screen so i can't look to answer that 100%
But i figured it out after my brother gave me that phone - he said he couldnt do that but i figured it out in 10 minutes.
Something to do with when you make the contact you need to change it to either the SIM card or um.. i cant think of the other name butthere are several options for what you save it as.
