SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
SOURCE: my lionel train won't run at all. What do I do?
Did you ever solve your problem? My son is having the same problem.
SOURCE: I have a Lionel ZW transformer older version
bad track connection.... clean the track with dry scotchbite pad, then wipe with soft cloth, or the connection pins are loose in the track. tighten with needle nose pliers
SOURCE: is lionel 40 watt transformer from toy train
need a larger out put transformer 90 watt or greater....
