Adp242 do not wash everything remain stain on all the items inside.The tablet doesn't dissolve and all the residue remain on the bottom.
Make sure that water is entering the machine as the first operation--open the door to check shortly after you hear the wash cycle come on. Water should be dripping from everything. If there are several inches of water sitting in the bottom, but nothing is wet, and you have heard the pump running, you will need to tear down the lower spray arm assembly down to the deck to clean the large intake screen at the bottom. Keep track of orientation and placement of each piece removed. Remove the large screen and soak it in hot water/white vinegar/detergent solution for an hour or so, then scrub the screen to help remove deposits. Inspect all holes in the deck surface for plugging--a wet/dry vacuum will remove most of this debris. Reassemble everything in reverse order. Inspect the spray arms for any plugging of holes and for any split seams. With luck, this should fix your problem.
