KitchenAid KCMS145J Microwave Oven Logo
Posted on Nov 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
KCMS145JBL-1 stopped heating. It overheated, shut down, then eventually lights and sensors came back on. Still doesn't heat.
William Miller
Level 3:
  • KitchenAid Master 9,179 Answers
  • Posted on Nov 29, 2009
William Miller
KitchenAid Master
Level 3:
Answers
9179
Questions
Helped
4478237
Points
21747
It's likely the magnetron overheated, and when its thermostat tripped, all power was interrupted for safety until it cooled back down.
You likely have a failed magnetron, which is sometimes due to a failed internal cooling fan or clogged filter.
Your owner's manual will help you on locating and checking the filters. Grease filters can be cleaned, but charcoal filters cannot, they must be replaced.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the turntable and stirrer won't work, and magnetron will soon be destroyed.
Sometimes the cooling fan will not run after the cooktop lamps have failed. A surge from the filaments shorting can cause damage to the control circuit board, resulting in odd operation from lights, fan, or turntable.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
You can find links to helpful exploded view diagrams and part ordering help here.
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
1helpful
Convection oven doesn't heat
Possible that the relay is faulty or there is fault on the control panel. It can also be related to problems on the thermocouple or sensors which can cut off prematurely the element.
Problem with KHMS1850S Stainless Steel 1000 Watts Microwave Oven
Possible that the Magnetron is powered off or is defective. You can check the main capacitor to the HT, check the leads, check the main board.
Also check the sensor which is mounted on the top or side of the cabin which is protector for overheat and can cut the voltage for safety.
If so also check the wave guides
Click on: Waveguides
9helpful
2answers
What do i do after my microwave overheated and shut off?
they have a built in overload thermo cut out when it is on for a long time it will cut out cool down and should be ok to use again
My Sharp microwave convection oven (R-967M / R96STM) cuts out during convection pre-heating and cooking, It appears it stops heating after 1 min. If the START button is pressed again the oven starts...
Also the fact it is a convection oven could mean the oven temperature sensor is not picking up the oven temp. it is not telling the machine it is there by the board seeing its resistance, the unit will shut off as a safety feature. The oven sees temperature by reading the value of a temperature dependent resistor. As the temperature changes so does the value of the component ( oven temp sensor) that way the unit determines the temperature inside the unit. Sometimes those sensors will break since they are in the area with the heat and moisture, they get old and break.
GE spacesaver jvm240av microwave shuts down during cycle
I have not gotten a solution for this problem. I thought your website said one of the experts would respond for free. Seems like that must have been a hoax to give you the opportunity to sell me something. Shame on you!
I am still waiting for the free assistance, as advertised.
Dave
6helpful
9answers
Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
13helpful
6answers
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Top KitchenAid Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
