Question about Casio Music
How can i connect my ctk-720 to my mac & the garage band application.
    New Friend:
Just did it today. Hooked up CTK-720 to Imac with Snow Leopard (10.2.6) using GarageBand.
Steps: 1) Go to : http://code.google.com/p/casiousbmididriver/ 2) Download the CasioUSBMIDIDriver.plugin (see the two choices on the right side of screen) 3) Place the CasioUSBMIDIDriver.Plugin file into the MIDI Driver subfolder: Macintosh HD => Library => Audio => MIDI Drivers 4) Restart 5) Plug in USB cable, open GarageBand, turn on Casio 6) In GraarageBand Open New Project, Start by using Piano, Select Keyboard (command K) in the Window menu 7) You should see the keyboard being played on the screen.
PS: Thank you Francois Ferland.
Posted on Nov 30, 2009
    New Friend:
I also am unable to get the CTK-720 to work with garage band or anything in mac. I went to Audio Midi Setup, called Apple and called Casio with no luck. any suggestions would be appreciated. thanks
Posted on Nov 29, 2009
SOURCE:
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Where can i get a ctk 481 driver
CTK 481 only has MIDI-IN and MIDI-OUT ports & no USB. So you need to buy a USB-MIDI interface (cable-like) preferably one that is class-compliant for you OS. Class-compliant device do not need drivers (PCs, MACs, IPAD).
Mar 08, 2014 | Casio Keyboard Ctk-481 Ctk-631 Ctk-651
How to fix ctk 7200 keyboard sdcard erorr
SD or SDHC memory cards must be between 2GB to 32GB
1GB SD card for earlier models or even 2GB SD formatted by earlier models are incompatible (folder structure has changed)
Feb 07, 2014 | Casio CTK-720 Electronic Keyboard with...
Computer does not have Ctk-720 driver
PC drivers available at Casio
http://support.casio.com/en/support/download.php?cid=008&pid=20
If you have a MAC google casio driver for Macs by 3rd party.
Jan 22, 2014 | Casio CTK-720 Electronic Keyboard with...
Can't connect my ctk-720 to my mac
The Mac needs the driver, and you may need to select it in Chooser as well. If it is not on the instruction disk, it should be downloadable from the manufacturers website.
Sep 25, 2012 | Casio CTK-720 Electronic Keyboard with...
What cable would I need to connect the audio output of a Yamaha Claviola to a Mac running Garage Band?
in order to make a good connection with digital audio i recommend using an audio interface i personally use a maya44 usb.
Feb 08, 2011 | Yamaha Music
I can't get d usb connection and i think the driver is corrupted
Make sure the driver is compatible with your operating system... often stuff will not work with Vista for example. Often SOME software REQUIRES it to be installed before USB cable is connected, and yet other requires it not be connected till software is installed... read the manual...
Jan 21, 2011 | Casio Ctk-5000 Electronic Keyboard Piano...
Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Nov 30, 2009 | Casio Music
Not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
Sep 03, 2009 | Casio CTK810 61 Key Keyboard
Music Logo
8,788 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Casio Music Expert? Answer questions, earn points and help others
