Sony PlayStation Portable (PSP) Console Logo
Posted on Nov 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help me accident remove my psp to computer! when im in download mode .when i select the game my psp automatic shutdown... what i need to do?
Anonymous
Level 2:
New Friend:
  • Expert 32 Answers
  • Posted on Nov 28, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
32
Questions
0
Helped
8282
Points
112
Your battery is dameged u should fix it
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
0
Helped
895
Points
17
Buy a new battery aand if that dont work give it to sony to repair. Its $89 to repair plus tax.
2helpful
How to get psp games
Try these steps : 1.
Check to see if you have the right firmware. Firmware is the proprietary operating system the PSP requires for functioning. You need Firmware 1.0 or 1.5 to download free games on a PSP. These versions allow you to play PSP homebrews; later versions have protections that avoid use of non-commercial PSP games.
To check your PSP's firmware, press the PSP's "Home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PSP.
2.
Format a PSP memory stick. The size of the memory stick doesn't matter since most PSP homebrews are relatively small. Insert the memory stick into the slot located on the left side of the PSP, where the directional buttons are. Pop open the cover and slide the memory stick in, making sure it's face up and follows the direction of the white arrow.
Press the "Home" button and go into the "Settings" section. Scroll down and select "Systems Settings." In the next screen, continue scrolling down until you can select "Format Memory Stick." The PSP will ask you if you want to format the memory stick. Answer "Yes," and the PSP will format the memory stick within just a few seconds.
3.
Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading. Visit the sites to gain a better understanding; links are provided at the end of this article.
4.
Unzip the files. Usually, when you download free PSP games, you receive files in a compressed (or zipped), format. This allows a developer to send larger files without the hassle of breaking them up into pieces. However, before you can use these games, you will have to unzip them so you can have access to the individual files.
To unzip files, you need to use an unzipping utility. Windows comes with one, and it's relatively easy to use since you just select options from a Wizard. But if you prefer something more sophisticated, consider using WinZip, for the PC, or Stuffit, for Macs. Both of these programs can be downloaded free, though the legal version of WinZip only offers a 30-day trial. Either way, unzipping is as simple as selecting "Extract" and entering in the name of the file you want your games in.
5.
Connect your PSP to the computer via a USB cable. Make sure you place the smaller end of the USB cable into your PSP. Place the larger end into any of the USB ports available on your computer.
6.
Switch to USB mode. The PSP cannot communicate with your computer unless it is in USB mode. This is accomplished by pressing the "Home" button, scrolling towards "Settings" and then selecting "USB Connection."
7.
Transfer the games onto your PSP. This step is the heart of downloading free games onto your PSP, and it is simple. With your PSP connected to your computer, take whatever games you plan on downloading and place them into the PSP > GAME folder. If this folder doesn't appear automatically, you can create one by "right-clicking" in the PSP directory and then entering in the name "Game."
8.
Run the games you downloaded. After you have installed the desired games onto your PSP, disconnect the device from your computer. In the main menu, scroll to the "Game" section. Select the "Memory Stick" option. The PSP homebrews you downloaded will be contained here. Highlight one of them and press "X." Assuming the homebrew is coded properly and you have the right firmware, it should run just like a commercial PSP game.
In case of any problem please revert back
tip
How to Download Games on a PSP for Free
1.Check to see if you have the right firmware. Firmware is the proprietary operating system the PSP requires for functioning. You need Firmware 1.0 or 1.5 to download free games on a PSP. These versions allow you to play PSP homebrews (later versions have protections that avoid use of non-commercial PSP games).
To check your PSP's firmware, press the PSP's "home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PS
2.Format a PSP memory stick. (The size of the memory stick doesn't matter since most PSP homebrews are relatively small.) Insert the memory stick into the slot located on the left side of the PSP, where the directional buttons are. Pop open the cover and slide the memory stick in, making sure it's face up and follows the direction of the white arrow.
3.Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading.
4.Unzip the files. Usually, when you download free PSP games, you receive files in a compressed (or zipped), format. This allows a developer to send larger files without the hassle of breaking them up into pieces. However, before you can use these games, you will have to unzip them so you can have access to the individual files.
To unzip files, you need to use an unzipping utility. Windows comes with one, and it's relatively easy to use since you just select options from a Wizard. But if you prefer something more sophisticated, consider using WinZip, (for the PC), or Stuffit, (for Macs). Both of these programs can be downloaded free, though the legal version of WinZip only offers a 30-day trial. Either way, unzipping is as simple as selecting "Extract" and entering in the name of the file you want your games in.
5.Connect your PSP to the computer via a USB cable. Make sure you place the smaller end of the USB cable into your PSP. Place the larger end into any of the USB ports available on your computer.
6.Switch to USB mode. The PSP cannot communicate with your computer unless it is in USB mode. This is accomplished by pressing the "Home" button, scrolling towards "Settings" and then finally selecting "USB Connection."
7.Transfer the games onto your PSP. This step is the heart of downloading free games onto your PSP, and, it is simple. With your PSP connected to your computer, take whatever games you plan on downloading and place them into the PSP > GAME folder. If this folder doesn't appear automatically, you can create one by 'right-clicking' in the PSP directory and then entering in the name "Game."
8.Run the games you downloaded. After you have installed the desired games onto your PSP, disconnect the device from your computer. In the main menu, scroll to the "Game" section. Select the "Memory Stick" option. The PSP homebrews you downloaded will be contained here. Highlight one of them and press "X." Assuming the homebrew is coded properly and you have the right firmware, it should run just like a commercial PSP game.
3helpful
2answers
Im using psp 3001 with version 5.03 PROME-4 and Signed 5.03 HEN v7 PROBLEM: When i always turn ON my psp a. blackscreen only b. power light is on (GREEN LIGHT) c. shutdowns every 20 seconds...
hold SELECT and START and TRIANGLE and SQUARE = hold these 4 buttons while you start up the psp, hold until the psp shows a blank screen, then it will show the initial setup screen.
2answers
How can i download free psp games ?
Follow these steps to Download Games on a PSP for Free :
1.
To check your PSP's firmware, press the PSP's "home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PSP.
2.
3.
Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading. Visit the sites to gain a better understanding.
4.
5.
6.
7.
8.
1helpful
2answers
How to play my psx game on my psp
This is a problem occurring in all the play station consoles....... this is mainly because of the poor quality of the disc.....as a result it leads to the damage of ur PSP lens..............use good original discs........the heating effect is due to the long usage of pirated discs ...
check your lens if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
1helpful
How do u download psp games
to learn how to download psp games, follows the steps below and you won't have any problems:
  1. Download desired game from an Internet game site onto your computer.
  2. Connect the PSP to the computer using the USB cable. The memory stick needs to be in the console at the time of connection.
  3. Copy the downloaded game files into the PSP game path on the removable drive. This puts the downloaded game onto the PSP memory stick.
  4. Disconnect the PSP from the computer once the game has been fully transferred.
  5. Look in the PSP main menu from the game folder. Scroll to "Game" and select the memory stick option. Press the "X" button to display the list of available games.
  6. Select the downloaded game and begin playing.
I hope this would be of help to you.
Take care.
How to download a game in the PSP?
Download desired game from an Internet game site onto your computer.Connect the PSP to the computer using the USB cable. The memory stick needs to be in the console at the time of connection.Copy the downloaded game files into the PSP game path on the removable drive. This puts the downloaded game onto the PSP memory stick.
Disconnect the PSP from the computer once the game has been fully transferred.Look in the PSP main menu from the game folder. Scroll to "Game" and select the memory stick option. Press the "X" button to display the list of available games.Select the downloaded game and begin playin
WHEN I DOWNLOAD GAMES IN MY PSP AND I OPEN IT IM TRYING TO LOOK FOR THE GAMES BUT THERE ARE NO GAMES BUT WHEN I OPEN IT IN THE COMPUER ALL GAMES ARE THERE WITH THE CORRECT FORMAT WHY THE GAMES CANNOT BE...
plug in your psp with the computer . from settings select USB mode. u ll have an access to the mem card from my computer as removal disk . search each folder where the games are copied and put them all into a folder names ISO . the games ll run .. plz vote.
2helpful
Triangle button on psp
you need to open your psp and clean or replace they d-pad
6answers
How can i download stuff from my computer to my psp
your ps3 cant find your ip addres youv got to put it in manuly
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
