Lexmark X6170 All-In-One InkJet Printer Logo
Anonymous Posted on Jan 14, 2008
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
I was copying the back side of my insurance card when the printer made a noise like strating to copy. It didn't copy. It displayed an error: Cartridge Error. 50C consult user guide
  • 7 more comments
  • ALRINE Feb 05, 2008
    CARTRIDGE ERROR 50C
  • Anonymous Mar 09, 2008
    Don't have my user guide....printer is giving a message of Cartridge Error 50C. Can anyone give any detail on how to fix ?
  • Anonymous Apr 19, 2008
    I have a Lexmark 6100 series with an error code: 0504. Color cartridge does not print; printer states color cartridge is missing, yet it is installed correctly,; what might be the problem?
  • mgwill May 09, 2008
    cartridge error 50c. I have purchased new ink cartridge. I have followed all instructions for troubleshooting.
    1. reinstalled cartridges
    2. reinstalled printer
    3. connected from power strip to wall outlet
    Nothing seems to work
    PLEASE HELP!!!!!
  • Anonymous Jun 04, 2008
    it recieved one fax and for the second time was displaying cartidge error 50c consnult your user guide. tried to clean it but not helpfull.
  • Anonymous Oct 26, 2008
    I ahd the sema problem replaced ther color cartridge and now get a color cartridge missing error...
  • Anonymous Feb 15, 2009
    I followed the instruction and nothing happened. what should I do?
  • ay8534965 Mar 20, 2009
    will not print - cartridge error LEXMARK X6100
  • Anonymous Apr 14, 2009
    "Alignment problem. Remove tape from cartridges or try troubleshooting."
    I have replaced the cartridges and printed about 7 alignment pages, opened and closed, replaced with new cartidges and nothing seems to be working. Maybe time for a new printer????
Anand Kumar
Level 3:
Genius:
  • Master 2,035 Answers
  • Posted on Mar 15, 2008
Anand Kumar
Master
Level 3:
Genius:
Answers
2035
Questions
Helped
851647
Points
5335
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
  • Pisstoff Sep 22, 2010
    Hear is How you solve the Catridge Error 50C on you Lexmark X5100. First you get in your car and drive to the neareast Harware stor and get your selfe a biggest baddes meanest Sladge Hammer. You bring that Bad boy home. And try to Print the dam page if it shows the Catridge Error 50C, then you just Smash that pice of $hi**t to death. And you will feel soo. good about it.
    And then call the Lexmark support center and give them you know what to make this Pice of S**t and not providing a answer to solx this probablem
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7710
Points
I need to up grade the X6100 software to meet window vista requirements so I can use my printer
A
Anonymous
The cartridge has a short in it and needs to be exchanged for a non-defective one.
Says erorr 50c on my lexmark x5150
The 50c error indicates a problem with your cartridge. This article will help you determine and resolve the issue: Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen.
1helpful
Installed refilled ink catriges,both black and color used for a few days all was well then, it reads Catridge Error -Error: 50C Go to users guide. what do I do Now cannot find users guide. plzzz help.
Though Lexmark does not recommend using refilled inks. You may refer to this article from the Lexmark website on Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen. If this does not help, try to insert a genuine Lexmark cartridge to determine if your other cartridge is faulty. Thanks.
Keep getting an error 50C and color ink cart. missing
Here's an article in the Lexmark website on "Cartridge Error 50C" and Other Errors on the Lexmark X5100/X6100 Series LCD Screen to guide you on what to do. Just click on this link: http://bit.ly/8Zf7ef. Follow the troubleshooting steps. Hope this helps.
3helpful
Cartridge error 50c
Here's an article in the Lexmark website on "Cartridge Error 50C" and Other Errors on the Lexmark X5100/X6100 Series LCD Screen. Just click on this link: http://bit.ly/cBu4mW. Follow the instructions carefully. Hope this helps.
1helpful
Equipment malfunction -cartrige error
Here's an article in the Lexmark website on "Cartridge Error 50C" and Other Errors on the Lexmark X5100/X6100 Series LCD Screen. Just click on this link: http://bit.ly/cOlN7n. Follow the instructions carefully. Hope this helps but if the problem persist after doing these steps, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. I hope I can assist you more on this matter.
2answers
6170 I HAVE A ERROR MESSAGE STATEING 50C CONSULT USER GUIDE AND I DO NOT HAVE A USER GUIDE
Hi. The error tells you that your print cartridge has shorted. Here's a link to the Lexmark website to give some instructions on how to remedy the problem. Just click on this link: http://bit.ly/aSWvpk . Good luck!
2helpful
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Cartridge Error
1helpful
Lexmark 6100 cartridge error 50c
Are you using a factory "New" Lexmark cartridge?
Lexmark does not support the use of refilled cartridges or third party cartridges in their products.
Lexmark considers this to be Product Tampering and will void the printer' warranty.
Don
2answers
Cartridge error error 50C consult user guide
Hello, error 50c is a cartridge issue. Try taking out, cleaning heads, returning and reprint. Cheers lilacgerry xxx
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
