have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
Hi ccraigo
To answer your question;
Your motorola will connect directly(not through the dvd) to the tv set into one of the input ,(preferably using hdmi or component cables for hd) and the dvd will use a different input,
All you have to do then is switch between which one you want to watch.
Hope this help Cheers
Your dvd recorder only has rca, red white yellow inputs it wont allow you to record in HD, although you can play your comcast box any hd, regular digital through and record. Hook up the comcast box if HD through preferably HDMI if not get one from comcast. The HD box is the only box that allow HDMI, component and regular RCA and some RF out. This way you can play HD to your set but also record through RCA or RF again will not allow for HD record unless its TiVo. Hope this helps
No HD channels on a DCT700, you have to have a HD capable box from comcast. Usually $8.95 a month for box rental. Don't know a lot about DVD players. If you get a comcast HD box, and have an HD TV, you should use an HDMI cable for best picture. Second choice is component cables. Those are the red, white and yellow or red, white yellow, blue and green cables.
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
It should be compatible with all of them. I have one that works just fine with my Sony HD/TV, HD DVD PLAYER, etc. The only difference is that its is stereo w/ a middle speaker hook up, if you so desire.
I find it just as enjoyable and easy to use as my Denon 6.1 with fewer speakers. That is because as men, our hearing range is poorer especially as we grow older.
The DVD player may have multiple output formats that can be displayed. Sounds like you have the composite output selected when you have the component output selected on the DVD player. Check the menu options on the DVD player and confirm they match the way you have the player connected
