Brother 1034D Mechanical Sewing Machine Logo
Posted on Nov 13, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bonjour, je viens juste d'acheter la surjeteuse brother 1034d, le fil bleu n'arrette pas de se casser, qu'est-ce que je dois faire. J'ai beau enfiler et reenfiler comme c'est indiqué dans le manuel et sur la video, mais ca continue a casser. Puis-je également avoir la version francaise du manuel d'utilisation? Merci.
Piotr Pachkaev
Level 3:
Master:
  • Brother Master 306 Answers
  • Posted on Nov 13, 2017
Piotr Pachkaev
Brother Master
Level 3:
Master:
Answers
306
Questions
Helped
106525
Points
1533
Hello!
I'm adding a link to manuals to this overlock machine.
It is available on Spanish and English. Hope it will help!
https://manualsbrain.com/fr/products/brother-1034d
5 Related Answers
Anonymous
  • Posted on Apr 06, 2009
SOURCE: threading brother 1034D
on u tube the show you step by step how to thread the Brother 1034d.
abozid
TCHNICAL SUPPORT FOR JUKI-JACK-PEGASUS
  • 180 Answers
  • Posted on Aug 20, 2009
SOURCE: visual inside brother 1034d overlock
kindly go to http://www.retrevo.com/support/Brother-1034D-manual/id/19095dj686/t/2/
you will finde manual for your machine
Anonymous
  • 3 Answers
  • Posted on Sep 17, 2009
SOURCE: Brother 1034D
I had the same problem with the blue thread- it would sew and inch then pop- mine worked wihtout breaking after I re threaded in this order: green, blue, red then yellow
Anonymous
  • 1116 Answers
  • Posted on Mar 16, 2010
SOURCE: How do you thread the brother 1034D serger? A
You can download a free manual at the Brother website http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_1034D_ENES_178.PDF
Anonymous
  • Posted on Sep 16, 2010
SOURCE: My 1034D Brother Serger foot raiser lever on
mine just did the same thing - i opened it up (you have to remove the light) and it's a small plastic piece that seems to be just glued into place to lift the pressure foot when it rotates... a bit disappointing - i will try glueing it back but i don't know if it will last for long. i am very disappointed!!!
2helpful
My Janome MyLock 434-434D Serger Sewing Machine Overlocker. Side door wont stay closed. How can I adjust this?
A mon avis, si la porte lat?rale de votre surjeteuse Janome MyLock 434-434D ne reste pas ferm?e, il y a quelques choses que vous pouvez essayer pour ajuster cela :
Assurez-vous que la porte lat?rale est correctement align?e : Il est possible que la porte lat?ralement ne se ferme pas correctement car elle n'est pas correctement align?e avec le reste de la machine. Essayez de la r?ajuster en la faisant glisser doucement vers la gauche ou la droite jusqu'? ce qu'elle s'aligne correctement.
Veuillez v?rifier que les charni?res sont bien en place : Les charni?res de la porte lat?rale peuvent se desserrer avec le temps, ce qui peut emp?cher la porte de se fermer correctement. V?rifiez que les charni?res sont bien en place et si ce n'est pas le cas, ajust?z-les avec un tournevis.
V?rifiez aussi que le loquet de verrouillage fonctionne correctement : Le loquet de verrouillage est ce qui comporte la porte lat?rale ferm?e. Si le loquet ne fonctionne pas correctement, cela peut emp?cher la porte de se fermer correctement. essayez de pousser doucement sur le loquet pour voir s'il se verrouille en place. Si ce n'est pas le cas, vous devrez peut-?tre le remplacer.
Bonne chance.
Como lenar bobina de maquina de coser singer 6235
https://arts-literature.blurtit.com/166387/how-does-one-fill-the-bobbin-on-a-singer-6235-sewing-machine
https://translate.google.com/translate?sl=auto&tl=es&u=https%3A%2F%2Farts-literature.blurtit.com%2F166387%2Fhow-does-one-fill-the-bobbin-on-a-singer-6235-sewing-machine
Gracias escritor
  • Comentario
  • Decir bruscamente
  • Farhan Khan respondi?
    Es bastante f?cil llenar una bobina; todo lo que necesita es leer instrucciones detalladas y tutoriales que podr?an ayudarle a enhebrar una bobina. Puede consultar este sitio web para obtener instrucciones.
    'target =' _ blank 'class =' qa '> www.ehow.com
    An?nimo comentado
    Tengo esta maquina (copiado del libro) Levante la aguja hasta la posici?n m?s alta girando el volante hacia usted; levantar el prensatelas plato deslizante abierto; gire el dial selector de patrones hasta que el color verde indique l?neas de puntos debajo de la Costura recta / Bobina de bobina. Coloque una canilla vac?a, con los anillos negros hacia arriba, en el estuche de la canilla; cierre la placa deslizante, alineando las marcas en la placa deslizante y en la bancada de la m?quina; esto engrana la bobinadora. Saque el hilo de la aguja, debajo del prensatelas y enr?llelo una vuelta en cualquier direcci?n, alrededor del tornillo del prensatelas, tirando de ?l hacia la ranura del resorte del tornillo; comenzar a correr la m?quina; La ventana de la placa deslizante le permite observar el devanado de la bobina.Cuando se haya enrollado la cantidad deseada de hilo, detenga la m?quina. NO DEJE QUE EL HILO SE VIENE M?S ALL? DEL ANILLO "COMPLETO" EXTERIOR. Retire la rosca del tornillo del pie prensatela; cierre la placa deslizante, devolviendo la m?quina a la posici?n de costura; levante la aguja a su posici?n m?s alta; tire de 4 "de hilo debajo del pie hacia la parte posterior de la m?quina, y corte. Para comenzar a coser, coloque la aguja en la tela donde desee, baje el prensatelas y encienda la m?quina.
    An?nimo comentado
    Muchas gracias por esta respuesta! Despu?s de pasar horas trabajando con otras respuestas, encontr? LA que me proporcion? de manera concisa las instrucciones de c?mo enrollar la bobina.
    Tenga un gran a?o ... ¡Y por favor siga respondiendo las preguntas como lo hizo aqu?!
    WCP
    An?nimo comentado
    Piensa por la informaci?n que funcion?.
    segundo
    Stuti Ahuja respondi?
    Recibir? un eje de devanado de la bobina junto con la m?quina. Fije un rollo de hilo en la m?quina de coser y p?selo a trav?s de las gu?as de hilo de la m?quina de coser. En algunas m?quinas, las pautas para enrollar el hilo son diferentes de las de la costura. Coloque la canilla en el eje y coloque el eje a ambos lados de la m?quina.
    Deje que unas pocas pulgadas de hilo pasen por un orificio en la parte superior de la bobina. Aseg?rese de que la aguja est? desenganchada mientras enhebra la bobina. Para comenzar a enhebrar o enrollar la canilla, presione el pie prensatela, debe sostener el extremo del hilo mientras se enrolla la canilla. Hay una l?nea en el borde de la bobina; deje de enhebrar soltando el pie prensatela cuando el hilo llegue a esa l?nea. Corte el hilo y la canilla est? lista para colocarla en el estuche de la canilla.
    Anvin Raj respondi?
    Enhebrar una bobina depende del tipo de m?quina. Singer Company fabrica diferentes tipos de m?quinas de coser. A medida que el modelo var?a, el m?todo de enhebrar la m?quina tambi?n var?a.
    En una m?quina general, en primer lugar, debe apagar la alimentaci?n y levantar la aguja, en la medida de lo posible. Levante lentamente el prensatelas. A continuaci?n, mantenga el viaje del hilo. Mueva el volante hacia usted de forma que la aguja descienda y se levante. Luego, tire lentamente del hilo de la aguja para obtener el hilo de la bobina. A continuaci?n, abra el bucle, y finalmente tire de los hilos hacia atr?s. De esta manera, podr? enhebrar una bobina de una m?quina de coser para cantante. Sin embargo, hay diferentes maneras de enhebrar diferentes m?quinas. Una vez que entienda c?mo enhebrar una m?quina, la pr?xima vez lo har? m?s r?pido que antes.
    An?nimo respondi?
    Simplemente tome el hilo que est? cargado a trav?s de la aguja y envu?lvalo alrededor de la bobina. Coloque el disco en el n?mero 5. Mueva la parte met?lica que cierra la canilla a la flecha. No cierres todo el camino.Presione el p?talo del pie y se cargar?.
    1helpful
    Me hace falta un manual para la brother db2 b797 y en que parte se compran accesorios
    Hola
    Solo lo encontro manuals en Ingles.
    Este es la lista de los piezas.
    http://www.brother-usa.com/ModelDocuments/Consumer/Parts%20Manual/PM_DB2_B797_EN_2279.PDF
    Y este es el manual.
    http://www.brother-usa.com/ModelDocuments/Consumer/Hand%20Book/HB_DB2_B797_EN_2280.PDF
    Si hace falta una traducion de alguna pagina, hacer me saber, que el Ingles es mi lengua materna.
    Creo que puedes comprar piezas en el sitio web de Brother o quizas ellos ti pueden decir donde se los venden.
    http://www.brother.com/index.htm
    Espero que este informacion ti ayuda.
    1helpful
    2answers
    Does anyone know 1) what manufacturer made the Beaumark 3300 sewing machine and 2) where I can get a manual for it. sbssi
    Hi.
    Beaumark is a top appliance manufacturer in Ireland. They built the 3300.
    Here notes on Beaumark Brand.
    Regarding the manual for the 3300, this unfortunately is not available for free download. Try using this form to contact Beaumark and to get the manual. Click here.
    Pour l'enfilleuse PFAFF
    Bonjour Claudette,
    Je n'ai pas de réponse à votre problème mais je peux traduire votre question si vous le voulez...
    Merci !
    Sylvie à : [email protected]
    Broder avec la singer tradition 2250
    AUGMENTEZ(LEVEZ) TOUJOURS le pied de presse quand le filetage le fil sup?rieur.
    Se quiebra mucho la aguja y la puntada esta floja
    Vaya a Singer.com seleccionan su país. Bajo búsqueda barre donde dice que “estoy mirando para: ” Chasque encendido eso y selecciónelo de los manuales de instrucción del menú de la gota abajo. En la barra de la búsqueda mecanografíe adentro 3116. No mecanografíe adentro apenas 3116 simples. Le llevará a la transferencia directa que usted necesita. La transferencia directa está libre. Estoy utilizando Microsoft Word para traducir esto así que espero que usted pueda leerlo. No soy realmente seguro como de bien es la traducción en esta cosa. La esperanza I ha estado de una cierta ayuda.
    Top Brother Sewing Machines Experts
    Mike Cairns
    Mike Cairns
    Paul Bade
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
