either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
You probably know this, but on an oven unit there has to be two different phases of 120 to make it work. Check the wires that attach to the oven unit to make sure that you have 240 when in oven mode. If you have only 120, find out which wire is not hot and trace it to its source. Is it miswired at the other end? Is it shorted to one of the broiler wires? Usually there is a schematic to show how the oven is wired. Check for anything that is common to both oven and broiler wires and make sure the wires are on the right terminals. With out seeing the sove it is hard to know what it going on. Hope that helps. Robin
The top element should come on when Broiler is selected. If both ovens have a broiler mode, then look for something failed in the circuit for the broiler heating elements (it's unlikely both broiler elements would fail together.). If there is only 1 oven with a broiler, look for a failed broiler element.
If we are talking about an electric oven. The oven coil is probably bad. Easy to test remove it and check for continuity. If it shows open cicuit them the coil is burned out.
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
