Question about Yamaha RX-V463 Receiver
Yamaha HTR-6230 receiver set up w/HDMI no sound
I have a Yamaha HTR-6230 receiver set up w/HDMI from blu-ray player and DVR. The volume only comes from the TV (samsung) when in DVD or DVR mode. Video is great, but the audio is from TV only. When in the tuner mode, FM radio plays great through the surround, but when I go back to the DVD it only plays from the TV speakers. TV is also hooked to the reciever w/HDMI. Any solutions out there?
  • jmhogan12 Nov 28, 2009
    I've done the basic setup a few times, but havent seen anything which offers to change that setting
  • jmhogan12 Nov 29, 2009
    update...this receiver does not play surround sound audio through the HDMI cable, you have to add another audio cable to the unit to get the surround sound to work. It was a great deal on the unit so I'm not too disappointed and it still sounds really good through an optical cable. My biggest disapointment is how difficult it was to find out the problem. I did'nt find any info on the internet or FAQ's from Yamaha about the issue, it was when I scoured over the manual again I found a note in the HDMI section stating that the other cable would be required. It had an analog type input for the DVD and unfortunately the DVD did not have this as an option for output, so I had to run the DVD audio to the DTR/Cable input on the receiver so I could use the optical set-up. It works fine and w/a all-in-one remote its no big deal. If I had to do it again though, I'd upgrade to a unit which runs the audio through the HDMI. Oh well, live and learn!
  • 405 Answers
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Posted on Nov 28, 2009
  • Alex Zoubkov
    Alex Zoubkov Nov 30, 2009
    I'm sorry, you are right. I did not realize that Yamaha has such a unit which has no audio over HDMI.
    New Friend:
I also had this problem. you need to call Yamaha Tech Support (in your country) and explain to the consultant that you need to set up your receiver to decode the Audio from the HDMI input (so it will play the sound from the HDMI cable). Yamaha Australia said that this function is not described in the book and also said its a stupid mistake on Yamaha's Manual. So just give them a call and they will fix it for you. It WORKED for me :D
Posted on May 09, 2011
Satavlad is correct in his update, it's just ridiculous the Yamaha would sell receivers that cannot output sound coming in over HDMI. but it's true...
Posted on Feb 25, 2010
    New Friend:
I figured out this problem a few months ago. i don't even know if you'll ever check this again. but,
the reason why it doesn't play is sound is bc... your dvd and dvr mode is probably hooked up via hdmi... if you check your box it doesn't have the audio part of hdmi... its just video.
#2 i had a hell of a time figuring out why didnt it work just pluggin in certain things.
bc hdmi only works via the optical cables. but you'd have to plug it in via just the component cables.
funny part is most systems plugs when hdmi is plugged in the optical plugs are turned off. (go figure)
#3 remember w/ this system... things plugged into components, only works via component output. composite w/ composite and the optical only works w/ optical... and so forth.
so that means that you can't connect your component dvd player to your reciever and have it output to your HDMI tv... you would need to plug component plugs from the reciever to tv.
Posted on May 26, 2010
    New Friend:
I found the same issues and the same little notation in the manual. I have a cable box hooked up to the DTR/Cable inputes, (HDMI and Optical Audio) to recieve the sound and Picture. For the DVD audio I again used the the only other optical audio input and the went into the settings and changed it's inpute to DVD, that along with the only other HDMI filled got me sound and picture for both of my componets.
I aslo find that the Yamaha HTR-6230 has substandard surround sound. I will be replacing this.
Posted on Dec 12, 2010
    New Friend:
I have wall mount tv hooked to receiver with hdmi, im trying to connect wii, to receiver how do i do it
Posted on Dec 31, 2009
SOURCE:
No sound through yamaha htr-5750 receiver and samsung blu-ray
That's because tha hdmi is desing to play sound to the reciver you may have to use out put sound from the unit.
Dec 06, 2013 | Sony STR-DG510 Receiver
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
Dec 28, 2012 | Yamaha HTR-5830 Receiver
I have my HTR 6030 receiver hooked up with a blu ray and am trying to get true 5.1 sound. Have a blu ray disc playing and have put the setting on "straight" on receiver as instructed by future...
If you only have sound from the front left and right speakers when it's set to STRAIGHT, it means the audio source is only 2 channel stereo. As the audio source is from Blu-Ray, the audio should be HD if you are using the correct type of audio cable.
I really need more information from you to give a definitive answer. If you are only using a RCA type audio cable (red/white plugs) from the Blu-Ray to the Yamaha receiver then you will only get left and right front channels on the STRAIGHT setting. This receiver does not have HDMI, so you really need to be using a digital optical audio cable to get true 5.1.
Please can you let me know how the BD player is connected to the Yamaha receiver if you need further assistance.
Thanks,
BElectric
Feb 05, 2011 | Yamaha HTR-6030 Receiver
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
How do I connect my xbox 360 to my yamaha HTR 6230 receiver?
Use HDMI because they combine picture and sound in one convenient cable. You can buy the cheapy ones because they work the same as the pricey ones with no degradation in sound quality or picture.
Feb 18, 2010 | Yamaha RX-V463 Receiver
I need help setting up the cables on my home theater system. I have: 3 HDMI cables 1 Coaxial cable Yamaha 6250 receiver Samsung 7000 series LCD tv Samsung Blu Ray player Shaw Digital cable PVR box (similar...
2 hdmi inputs on samsung tv? different ways you can do it.if it was me i would run samsung blue ray to tv hdmi in,shaw box [if supported hdmi]to tv in, if not coax.
and i would sound out on tv to yamaha?
Dec 20, 2009 | Yamaha HTR-6130 Receiver
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
Hi, I just purchased a Panasonic Blu-ray Disc Plaer DMP-BD35. I am attempting to play the audio through a Yamaha HTR-6230 AV Receiver with 5.1 surround sound. I am using an optical cable. I am unable...
Check both for Optical
1) Check your DVD player make sure it is set to Dolby Digital or Optical Out or even AUTO (if applicable)
2) Check the Input source to the receiver say if you are using DVD on the receiver make sure the digital setting is set to either Optical or Auto
Nov 25, 2008 | Panasonic Televison & Video
No sound coming out of back speakers when watching DVDs
Make sure you have set blu ray player out put to bitstream,if you have set to pcm for hd master audio and dolby true you need to have a amp to decode this and hook up with a hdmi cable.If your amp has hdmi in and out but no high def audio you may still get multi channel audio.
Hope this helps.
CABLE GUY.
Mar 06, 2008 | Yamaha HTR-5790 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha RX-V463 Receiver Logo
11,900 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
