Question about Philips PH62080 Uni-Directional Microphone Microphone
Phillips microphone plugged into stereo input and cannot get it to work
  • 1,056 Answers
The stereo input is not sensitive enough to amplify the small electrical current coming out of a microphone. You need either a mixer or a pre amp to do that.
Posted on Nov 28, 2009
SOURCE:
I need to sync my snowball into cubase sx... its only recording on the left input not the right input of the audio wave. please help get back to work.
This is strictly a software setup problem. I use Sonar, but Cubase has to have the same features. Look for a PAN control and also where you MIGHT be able to select that both channels of the stereo are mapped to the single input. A work-around might be to bounce the input to a second track and then do a channel swap on one of the stereo channels, then combine them. I think Cubase uses the word "flip".
Search your documents for keywords: flip, bounce, swap, pan, and assign input. You can also copy and paste the recorded channel to a second stereo blank channel before flipping it and combining.
Mar 14, 2013 | Blue Microphones Snowball Professional...
B2 Pro left stereo channel is Mute
This is not a stereo microphone. There is no left channel. If you are recording into a stereo input, you need to split the input into two mono inputs, and record each channel as a mono track.
Feb 02, 2013 | Behringer B-2 Pro Professional Microphone
When I record vocals with stereo setting it always records left more in favour of the right. Is there a way to fix this?
Your microphone is a mono input (one), therefore recording in stereo is not practical. Stereo inputs are left and right (two inputs). Whatever your recording setup or audio workstation, the track you record to from your microphone needs to mono.
Jun 29, 2011 | Samson C03U Professional Microphone
Hi... I cannot seem to capture my audio in stereo. The playback from my mic comes from one side (mono) only. How do I set it to play through both speakers? I have 2 input mics...1 one camera and my...
Your microphone has a stereo miniplug, with 3 contacts, that look exactly like headphone minijacks. You have not stated where you are trying to plug this microphone, but most computers /sound cards will accept only mono minijacks, with 2 contacts. Should you have left/ right inputs for microphones, buy a splitter adapter that will turn the stereo jack of the microphone into two mono jacks.
Aug 23, 2010 | Sennheiser (EW100ENGG2C) Professional...
Roland DR-30 Mic - how do you use it?
If the mic is a dynamic microphone, you would need a small mixer. The line input is a high level input and the mic level needs to be boosed. We here at Pro Line Music have small mixers 215-736-8055
Dec 26, 2009 | Roland DR-30 Microphone
Microphone for my YAMAHA HTR-5440
Let me make this clear to you that your Yamaha does not support Microphone but the trick is you can still do it. All you need is a stereo jack to a RCA connector cable.Check this out http://www.mediacollege.com/audio/connection/jack-stereo-rca-2.html It is easily available in the market. The stereo jack will fit into your microphone and the RCA to your Amplifier/Reciever. Plug the RCA into CD/Tape input but not in the Phono n do your thing. Let me know if this works,coz I'm really curious.
Jun 02, 2009 | Yamaha HTR-5440 Receiver
Microphone doesn't work with small plug
I'm just taking a stab in the dark here but bare with me on this, I got a lot of info stored in this old head so it takes a while.
If you look at the jack for the microphone, Does it have 2 sleaves and a pin or just 1 sleave and a pin. If it has 2 then you will need an adaptor (Normaly Stereo jack to XLR). If it has 1 sleave then your going to need a preamp.
Apr 20, 2009 | Computers & Internet
How to get a new Microphone I purchased to work
your stereo most likely has an audio input in the back. 1 red and 1 white. It's usually labeled "AUX". Go to your local electronics shop, (radio sh**k) and get an rca audio cable where on one side it's 2 cables (red & white), and on the other side it looks like a headphone jack input or female Your microphone should plug into that side, unless your mic has the big jack. In that case just get the adapter to go from big to small. The red and white part of the cable will go into the AUX input on the back of your radio. And that's it!
just press the AUX mode of your stereo and your mic should work.
May 20, 2008 | Audio Players & Recorders
When I record using my microphone I hear "pops" and 'hissing" when listening to the playback. What can I do to prevent this? The moment I plug in an external mic (a Sennheiser) a low level rumble starts...
These mini video cameras are great for a lot of reasons, but the drawback is the tiny buttons and connectors, like the microphone input. It's probably actually a stereo microphone input.
If it is stereo (check the manual), then try using a stereo adapter, where you plug the adapter into the stereo mic input on the camera, and then plug the single microphone into only one side of the adapter ... then copy the audio to the "missing" side later in production ...
Alternative: record the audio separately onto a decent quality audio recorder with proper microphone jacks, then find the corresponding audio and synchronize it in software production. This is often how professionals do it, and one of the reasons you see the familiar "clapboard" snap at the beginning of movie shoots ... clapping your hands on camera right before you shoot will give you a visible action that will correspond to a peak in the audio soundwave that you can match up to synchronize the audio once you put the video and audio into your computer.
Another alternative - new item these days is an audio interface for video cameras that is basically a small black box that mounts onto the video camera or tripod, plugging into the tiny input on the camera and providing XLR microphone inputs ... just go to Borders and pick up any magazine on video production, you'll see them advertised all over the place ...
Good luck, hope I have helped in some way!
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Dec 18, 2007 | Sony Handycam HDR-SR1 HD Camcorder
Philips PH62080 Uni-Directional Microphone Microphone Logo
451 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
