Vacuums Logo
Posted on Nov 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't come on when I plug it in. Does it have a
Won't come on when I plug it in. Does it have a reset switch?
Anonymous
Level 3:
  • Master 438 Answers
  • Posted on Nov 28, 2009
Anonymous
Master
Level 3:
Answers
438
Questions
Helped
477808
Points
2625
Greetings from GoVacuum,
Yes, the Riccar 4812 does in deed have a reset switch. Unfortunately some dishonest repair man will tell you at this point that your motor has gone, but 7-10 times it's the reset switch.
If you look down at the base of th vacuum cleaner at the vacuum bottom in the back, right above the rear wheels, you will see a small red button. Take a ball point pen, and while the vacuum is plugged in, go ahead and push the red button or the reset switch. Did the vacuum come on?
If not, it may another simple problem of the cord/ plug going bad.
I hink if it just stopped workint all or a sudden, it's prbably the reset switch.
If it's not, please email me or give me a call and I then diagnose the problem for you.
Chris Jones
GoVavcuum.com
[email protected]
1-866-468-2288
MY VAC WONT START
check on /off switch, wiring, and motor. please be safe.
Dc17 won't turn on
there is a reset button under the cover that houses the on/off switches. remove the handle/wand and look on the back (where the top of the hose sits) for 2 screws (its a torx/star head screw size t10 i believe). remove them and locate 4 small locking tabs that hold the switch cover to the frame of the vacuum. Depress them and pop the cover off (2 towards the top and 2 towards the bottom). Youll see 3 switches (2 square red buttons and one small cylindrical shaped one). Push the small red one (the one to the left if my memory serves me right). you should hear a click. if you do than the switch is reset. if not check all connections to all 3 switches. if you see nothing loose or not connected, you may need a new brushbar motor.
I have a emerson insinkerator that has nothing working checked breaker and reset button??no power??
First check that you have voltage at the outlet and that the switch is working. There is a reset button on the bottom of the unit - have you tried to reset that? If not, try it! If that doesn't do it, unplug your unit and use an allen wrench to rotate the motor (CW), if it won't turn then you either have something like a bone or spoon wedged in it or the motor is bad. If the motot is bad it is cheaper to replace than to repair.
Hi, My Henry hoover has stopped working about 10
Check the motor brushes as well as the on/off switch.
3answers
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 • Vacuums
Cuisanart 10 c programmable coffeemaker won't work; no light comes on & it is plugged in. It has been working fine.
Check it's fuse inside, a blown or open fuse will cause won't work. Similar also happened if the cord wire is already open. Same goes also if the power switch is already defective. Either of those I mentioned will cause the unit not to work.
Thanks for asking.
Jun 25, 2011 • Vacuums
I have an electrolux discovery II vacuum cleaner and the floor function works, but when I try to switch over to carpet mode, it doesn't seem to engage.
There is a red reset button on the back of the machine. When it trips, the brush won't engage. Press the reset button and then try your machine again.
7helpful
2answers
I have a Hoover Mach 2.7 Windtunnel that shut off during use and wouldn't turn back on. Was doing kitchen floor and running fine. Though a breaker tripped but didn't...what could it be?
It sounds like your thermal reset switch inside of your Hoover may have gone bad. When a vacuum cleaner doesn't turn on it, it's either caused by one of four things.
  1. Electrical Short in your Cord.
  2. Plug has gone bad.
  3. Motor of your vacuum is faulty
  4. The On / Off Switch has gone bad, and/or your Thermal Reset Switch has gone bad
Since this happened while you were vacuuming, I would guess that this is either your electrical plug that's shorted out, or that your thermal reset switch has shorted out. Your model Hoover was built with a protection system that is supposed to automatically shut down your machine if it senses any excessive heat. This mechanism is controlled by a Thermal reset switch which is located in motor compartment. This part is notoroious for failing, even when there's no overheating that's occured.
Before you disassemble the entire machine to check this part though, I would try testing the On / Off switch in your machine, as well as testing the electrical cord, which will also let you know if your plug has gone bad.
Here's a link to a solution I've done here on FixYa explaining how to check the On / Off switch;
http://www.fixya.com/support/r4530569-replace_off_switch_hoover_windtunnel
While you have this apart, you can use the same electrical tester to test your cord. Simply put one end of the test into the terminal from the switch, and the other end of the test on one of the metal prongs that plugs into the wall. See if you have continuity here, if not, switch to the other prong of the plug and see if this helps.
If not continuity, this means your plug, or your cord has failed. If you do have continuity, this means that it's either the On / off switch, or the Thermal Reset Switch that's gone bad.
Here's a link to the solution that I've done on here showing how to replace the Thermal Reset Switch on your vacuum cleaner:
http://www.fixya.com/support/r4999778-replace_thermal_overload_switch_hoover
If you'd like some more help diagnosing this vacuum, please feel free to just use the comment field on the bottom of this page. I'm always happy to help you do some more advanced diagnosing, or answer any questions you may have.
If you found this solution helpful, please be so kind and rate this repair helpful, or leave feedback for me. This is greatly appreciated by the FixYa community. Thanks so much,
Chris Jones
GoVacuum.com
Top Riccar Vacuums Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
